Thanks mate :) I spoke with Russ earlier about sharing his evo5, but he suggested we both use the R35...... navigate alternately for eachother. So we're in with a chance :D
Excellent. That's good news Ben. I hope you can make it.
Thanks Coop, hope to mate :D
Well done to all at Rally Tas on the weekend, Kel especially. Good time had by most by all accounts, Kel, good stuff :) Great to see Quinny through for a win too :ermm:
Someone who's spec C didn't finish the event too flash :) ;
Rolled big time, 7 to 8 times, crew ok
Edited by Marlin
Bloody hell, 7 rolls over - as long as he's ok!
Quick question though; why would you run a spec c rex, or a type RA etc over a normal STi in Targa - they're all the same mechanicals arent they? Unless some JDM models get a significant HP increase...
Thanks Coop, hope to mate ;)
Well done to all at Rally Tas on the weekend, Kel especially. Good time had by most by all accounts, Kel, good stuff :( Great to see Quinny through for a win too :)
Someone who's spec C didn't finish the event too flash :D ;
I will have to find my carnage pics and post! There was plenty of it, especially on Savage which should bring back memories Benny ;)
Anyone who came off this weekend didn't do it by halves that's for sure.
And thanks for the congrats- I had an awesome weekend and was just happy to finish - top 5 was a bonus.
It was brilliant to see Quinny win - he fought hard for it and deserved it, especially considering he is running a relatively 'undeveloped' car with road tyres.
Better get your finger out and get that 35 ready for Targa Tas Russ :)
PS: Hats off to Timmy- teh master navi!
Yeh how rediculous was it that they continued the stage even after that mazda crashed in a big way and was taking up 3/4 of the road. And the fact that the crew were standing on the outside of a corner carrying on like headless chickens it was enough to startle you!
I can definately say my weekend was probably one of the more interesting ones, I learn't ALOT over the weekend and met ALOT of great people. Kel your a champ! and a caring one at that!
It was a worthwhile experience and I think I taught my driver alot in the three days, so hopefully it helps him in further rallies. It felt a bit weird being the master as opposed to the apprentice.
Im looking more and more forward to Targa and futher rallies this year and hopefully some good news!
What is AASA? Austrailian Auto Sport Accosiation? All i really know is CAMS because all the events up this way are all cams events.
There is no way my car will meet the M2 catigory at all cause it fails on about 10 criteria for being over modified but i'm told by Some people i've talked to that it'll probably sneak in under PRC rules which the event is also open to. I'm not a hundred percent sure that mine will pass but we'll see. They have let a few small curly ones slide in the past..... :P
I sent Russ a email the other day to see if he'd be keen so hopefully he hasn't commited to anything else that weekend. Be good to have the RGM boys back up for another event. Otherwise anything I can do to help people make the journey up to Townsville possible, just let me know.
The GTR doesn't fit the criteria for PRC and it'd be a dog with restrictors, but who cares... in the interest of getting the event off the ground eligibility shouldn't matter too much anyway.
What’s the entry fee? I'm keen to sending either the Evo or RX7 north during 2010
I answered my own question on the GPS @ rally tas btw
tried it on the first leg, realised it was just a distraction, and left it off for the rest of the rally (didn't even use it on the touring stages)
but then i also had to go through my notes after leg one and delete any distance call less than a 100- we were going so quick i barely had time to get the shorter distances out before needing to call the next corner!
anyone think the chicane on oldina was too small? apparently there were a lot of complants about it.
we were warned about it being tight so I cautioned it but in the end it didn't seem that bad?
hmmm think i better sort that one out!
highest bidder? :)
Chicane on Yolla was a little open, but they are something to drive by eye... didnt see any problem.
The place ment of bollards meant the roads were very clean... good thing. Broken pass mirror - not so good LOL.
I am glad they didn't stop Savage east for the mazda... it was no worse than the escort or jag. The guys were a little excited, but that meant you could see them. We get all the road and they had only blocked one lane.
Great little event... and one we will do in the future.
TT
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
