Glad to see everyone getting pumpededed :)
I too am catching the fever, just booked flights to come down and lend moral support and try and watch a few stages! You guys better be prepared for a stage streaker!!!!
I'm arriving the 30th and am out on the 3rd after the epic pissup "D
Yeah it's getting there. I just hope it's all sorted when it gets back
Yeah Chris worked on it all day yesterday.
The good news is he is coming to Tas next week now as well. He's sitting in my silly seat :)
Saw your car in the flesh today Matt - it sure looks sweet.
I put my car through its paces today and it passed with flying colors. I also found someone to jump in the silly seat so it looks like I'm going to be back in the game!
Team Last Minute FTW.
Team Last Minute FTMFW!
Our car was finished off on saturday, its back to the original 944 Big Block after the 968 disaster last year.
Signwriter today, dyno tomorrow then on the boat later in the week.
Posts like these leave me sad and give me the feeling you'd already moved on :(
On the upside, I can't wait for you guys to whip Snowy with under 3 litres of naturally aspirated pus. :P lol
Edited by Marlin
Moved on? Never! Just a broad minded person!
Im sure Snowy will have some excuse if we beat him...
Team Last Minute isn't that much FTW anymore. LOL
I'm struggling to get across to Tas (I do have a Sat night booking which means I will have 1 day to recce the whole event currently) and at this stage the 1st boat home is May 9th! LOL
And beds in Strahan for Sat night......... HAHAHAHA - yeah no.
But - I am offically in! http://www.targa.org.au/Competitors/profil...0Early%20Modern
Did you try Toll Shipping? and fly into burnie?
Its funny, we put our entry in over a week ago and still not up there.
Strahan, lol! there is zip, I musta made like 100 calls.
Try the spirit of tassie frieght 0364217322. Thats how I got my car over and back to Racepace this week. Only thing is you would have to fly over.
It's OK - TTTNOJDB it is.
I have to say you picked a tough year to do Rookie though Matt. There are 4 pretty damn decent steerer's that I know of in Rookie this year. Glad I did it last year thats for sure. But Rookie should make for some interesting following this year.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
