Not sure anyone is saying the 6 speed is weaker, I get that Snowman had problems with his, and went with the 5 speed for both cost and better ratios.
Circuit racing /= Targa though so using Super Taikyu as an example is probably pointless.
Same basic spec cars, about the same power, so i thought it would be a reasonable example that there is nothing weak about the 6 spd, nor did Nissan engineer down the quality of the drivetrain or later models. With no Grp A like in teh R32 days, and JGTCC so removed from road cars, i suspect Super Taikyu had even more importance to Nissan with the R34
the gearboxes in FD RX7 are clearly far far stronger than 32, 33 or 34 GTR... one day you could all become enlightened and pass over to the dark side !!
that is because a rotor lacks the torque to brake traction let alone gears. :)
Is the Targa DVD going to have any extra content in the main doco than the TV Doco? The doco's 10 years ago were much better, I watched a couple leading up to Targa, and they were longer, and showed a bigger varity of cars. But they did come out months after the event, as opposed to weeks.
I asked to Mazda crew when I was sitting between staged if they carried spare apex seals around with them...they didn't see the humor in it. Any gearbox could last behind a rotor :)
I meant the 5 speed is a benefit not so much because it is (marginally) stronger, but when coupled to the matching R32/33 diff gears they're better imo for this type of motorsport.
Anyway, I couldn't give a shit and am ready and waiting to move on :wub:
Roy is talking about anal now, has no one noticed?
Savman, yup, Mt Stuart for the 32. I better get to prepping the poor old girl. Straight after Superlap.
I'd like to apply for a derived time for the hour of my life lost last night and I'll happily take the penalty.
Apparently the Early Modern category (of which the majority of this forum competes in and watches) wasn't good enough for a mention or a final classification on the Doco.
I know not everyone can make it on the doco, but shit to miss a whole category??
as I said before, EM seems to be the black sheep so enough with the bickering... to busy arguing to realise your all getting screwed
was the most entertaining category too... close racing, crashes, mechanical failures and a bit of controversy all thrown in the mix... more interesting than F1 anyday!
Roy that's a disturbingly perfect analogy...
I'm not surprised really.
WOW...Quiet in here :D Even after Bris brought up Anal LOL
So I am finally coming down from the high of Targa...
Whats next for peeps....Hi Country seems so far away :)
Is Classic Adelaide really gone under?? Any more news?? I know some where worried that they have lost there earlier bird entry already.....
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
