I would rather eat a fresh dog shit than run a 33. :P
See you friday Savman, lets see if you still call me a homo then? Atomic wedgie for you.
Nick, I'll keep it in mind. I'm struggling with the idea of it at the moment.
Yeah they are Andrew.
A couple have been run before. No one having a real crack though. There's no reason why a 33 wouldn't be good, but personally I have doubts over the 25's ability to run six days with a sik amount of knock and ping like my 20 did :P
All this talk about S6/7/8 RX7's, I really didn't like the pedal arrangement, felt cramped and very offset. plus i think from memory the wheel wasn't central to the seat or something? Uncomfortable anyway.
Lets talk FWD... Lol! I reckon Snowman should get back to the idea of a Scirocco or Gti-R Golf or something.
Fact of the matter Damo is they aren't going to move the categories again while certain rear engine $6 figure cars are winning so comfortably, So I can't see the R32 being a "classic" until atleast 2025. By that time either none of us will be Tarmac rallying and therefore not give a shit, the world will run out of oil and we will all be racing in retro hybrids/electrics, or between you, savman, Benny and Roy you will own the last remaining GTSt's in the world and be running your own one make series.
Go figure :P
I wish I knew that...I wouldve kept my high flow and stuff and built the car around that...I guess standard turbos are cheap and easy to fit.
But yeah It would need decent internals in the 25...and not a dirty 30 that im building...might keep the 25 for a rainy day and have a read through the regs.
you'd need to do a heap of oil control mods to keep oil out of the cam covers and catch cans too.
Funny how the R33 is a better car, but no one wants to be seen racing in one
Cos they are the Commodores of skylines, every wanker with a UNIT hat drives one
The 32 GTS-t can hold it's head up and compete in the Early Modern category.
Can you imagine how much different it would have been this year if I was back there with the Plough?
That's right lads, if I hadn't of crashed or broken it, and had somehow retained the world's best navigator, I would have smacked you senseless. :P
I would rather a wart on my dick than an MR2. Every time I've come across one on a stage it's either spinning like a top or already backwards into a tree.
Stick to ya roots Roy.... front engine, rears wheels drives.
Edited by Marlin
RB25 definitely harder to keep alive than a RB20... I should know I had to rebuild my old one twice... good cars if you can get over the whole 33 'stigma'
plenty of bad 32s around too... and don't even get me started on 34 drivers;)
Im on my 3rd one in 3 years....so far a 200 dollar stocky bottom end is doing better than my (and I use the term loosly) "built one"
yeah I 'built' one too... cheaply... didn't end well... actually it didn't start well either, had piston slap from day 1 and ended up spinning a bearing while at the top of 3rd at sandown... lasted a while though... maybe it wasn't a good idea to run the stock ecu with speed cut and instead of shifting to 5th at the end of the straight just leaving it in 4th and banging it off the limiter few times.......... oh and oil coolers are for pussies........ ahhh good times
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
