I know where you're coming from cyclone, and I agree, it's not quite within the spirit of the rules IMO.
At least if you went to a Lambo they could actually sell you an LP560-4 Gallardo Super Alphabet. They'd ask of you wanted E-gear or sequential dog box, and would no doubt offer much respect when you specify the S6 doggie :)
Edited by Marlin
Is this skylines or rotaries Au?
If you are nice to a certain person within Mazda Australia, I'd bet he'd more likely provide the specs, much like he did for previous SPs. Could be wrong, there has been some mention of other than the rally ones being produced......all you've got to do is add the balls of Steve Glenney, to hope to run against things of 2 to 3 times the power.....a commodity in seriously short supply unfortunately.
mmmm I am confused, Mazda RX8 SP you cant buy but is running, R35 RC you can buy but you cant run it, I dont know how does it work ?
You would need to talk to Allan Horsley the Mazda Motorsports chief about building you one, I can give you his number... but I wouldn't even consider calling him unless you have 6 figures to play with :P
I wouldn't care about some italian giving me respect, i'd want to know if she was giving me a blowie :P
To be honest watching the RX8 in action and watching numerous incar/knowing steves driving style, it looks like an absolute handful to drive, far from enjoyable. GTSt would be heaps better package :P
Mate I dont want another chook cooker I have an RX7 SP copy I want to sell as it is. I want to Turbo charge another manufacturers NA rear drive sports car and I have three sold if we can run them, and yes mate build cost well into six figures but its better than being lazy and just buying a squashed combi.
Edited by CycloneGTR
Undoubtedly! No need to worry about vital parts exiting the engine either - if he was even smarter, should've continued with the emo :P - in-car of the old Nissan bus, from when ever it was, appeared to be armfuls of understeer, but at least it stayed on the black.
370Z ?
Surely you jest Trez?!
Snowy, both cars are for sale mate.
Yes, I know what's doing.
The next weapon is in the build now, already in bits, with other faster bits going in.
yarp jesting Woo.
Its no sweet sounding rb20 though!
mate, if I wasn't engaged we could get hitched. just think. forget double the wardrobe! double the garage!!! plus we are both tall bastards so all our cars would have nice low seats for headroom and legroom. E30M3, few GTRs, your radical. match made in heaven. you pitcher or catcher? lol.
Depends on the day of the week sideburns :kiss:
But you do make a compelling argument...
If only the E30 was eligible for Classic. :(
So for late classic, whats everyones pick of stuff that can possibly be afforded? From the nissan stable its a DR30 Skyline I guess?
Mazda Series IV RX7? Rotor questionable reliability
According to wiki 10 Sierra RS Cosworths were registered in the UK in 1985.... possibly drug money to buy and get parts for....and the RS500 wasnt avaiable til 87 apparently....Would it be any good anyway?
Any other potential wolves in sheeps clothing out there?
VC or VH Brock
Rover SD1
Bluebird Turbo
:D
yea the jap spec bluebird with the z18 turbo came with IRS back in it to. maybe a cheaper alternative to building a dr bar the fact they are ugly as sin. haha.
one of the blokes down here built one as a gravel rally car. i think they won there class 2 years running.
timmy has spoken to the bloke that has it in length as im not sure im alowed to make this public knolage.... but he used to have one..... and it was modified..... haha.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
