They are a good handling car (for their weight) Im sure with all the luxo stuff pulled out they wouldnt be all the heavy.
Edit - 1750kg in road going form
and a tasty pic
Another edit - the Group A Jags weighed in at ~1400kg
So similar weight to the Commodores/Mustangs/Falcons/Camaros etc that would run at targa
Yeah Timmy's right. You've been able to put 100m guards on MS cars for years. Not 100% sure if the proper Group C guards on RX-7 are within 100mm, but I understand the Commodore Group C guards are slightly more, so to get the right period look for these cars the rule will be expanded to say something like 100m, or those used in regonised championships are acceptable... this will overcome the issue with some other cars currently doing this anyway.
You can already run the front bumper and wing under the aero rule.
They aren't that bad, here is a clip of my mates IP RX7 at Bathurst
Why the F@#k can't you embed?
the RX7 in front doesn't seem to have any issues with torque... it just frys them off the line!
so many good ideas in the last couple of pages but be honest... you'll all end up in Emos :laugh:
I've been talking to damo about it for a couple of years. He thinks it's dumb, but I think a XJS (with a lot of work) would make a very compeditive classic. Weight is the big problem though
but seriously..... who wants to be caught in a Jaaaaaaag.........under 50?
let alone modify one.....
look @ ur link - youtu.BE, make sure it's proper link and it works automatically.
youtube been producing odd links lately :(
An XJS ran in 94/95ish era. Most memorable thing, sparks and flames flying out of the wheel spokes at the hairpin at Symonds......after 1 lap. Must have done a fair bit of field and fence work during the afternoon stages - day 4. Don't think it was a good year for British racing green, 2 tonne pussy requiring some overnight heroics at Burnie too, if I'm remembering my years.
There is a bloke locally who has all the tricky bits after being Jag driver of the year worldwide and given boxes of parts, he''d want Gallardo money for them though, if you that attached to oil leaks.
To set the cat among the pigeons, an 037 Lancia looks like it can run classic in SS :rofl2:. One that was out here in the early 80s and failed to find money to run in the ARC, returned a year or two back too.
Maybe it's time I pulled the"Two Ton Pussy" out of retirement and ran it again
I was disappointed you didn't dust it off this year!
I just got the RX-7 back from the bodyworks and had forgotten just how high SP wings were... years ahead of their time in shopping trolley design!... but I reckon the SX-R would give it a run Jeff?!
Edited by t01-100
Not a dry sump no. You can modify the standard sump with traps/gates and/or increase it's volume it to reduce surge
There has previously been a R32 running in the Demo Class (non-competitve) that more than likely did run one.
82. Sump / Oil Filter (except Showroom)
The removable section of the sump maybe modified to increase capacity and internal baffles may be fitted. Sump pickups maybe modified to allow for modified
sump depth. The oil filter element/cartridge/s is free, providing the cartridge fits without modification and does not perform any function other than filtering the oil.
modify the pickup and put gates in the sump and a GT-R will be fine. Our R33 GT-R did 5 Targa's, 2-3 3 day rallys, Eastern Creek 6 hear, and a heap of club day work with no engine problems. When we pulled it out for a check, it had only slightly marked bearing #6
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
