There's a few 98 guys that will be doing the same I'm sure! (I'm one! LOL).
we're planning on filling dad in queenstown, and just after arrowsmith.
Anyone know if the moron in Roseberry is closing his BP for Targa again?
Is it that badly tuned (or that illegal) that it needs that much fuel? :ermm:
Haha - no. But its what? 61 hard kms to Mt Arrowsmith - 56kms in the stage - and then around 100kms to the refill point at lunch.
So Ideally I'd fill up once half way through Arrowsmith! LOL But TO BE SAFE I'm going to want 20L before and 20L after (although 20L in Queenstown will work just as well).
you planning to fill at Roseberry? The guy hates Targa, and closes every year just to protest it.
Good to know! Will make other plans! LOL (This shite NEEDS to be the event guide Stu!)
The funny thing is the guy could double his 98 sales in one day for the whole year if he stayed open! LOL
other side of queenstown wouldn't be a problem for us, it's not much ferther up the road. Dad hasn't done any fuel burn tests with the 700cc injectors yet, so we have no idea of fuel consumption.
If you fill between Queenstown and Arrowsmith you'll be stuck in there until road re-opens Ben. That's why most fill before Queenstown, then diverts around the back to Hobart. Not the end of the world if you plan on being right down the back with Jim and YT though :ermm:
0.6/l is pretty eficient, last year we wored on 1/l km compeditive for the big stages with lots of WOT
Well I don't have a 56.6L tank so it better not be 1L/km or else I'm not getting through Arrowsmith! LOL
Stop worrying, you'll be fine. We pissed it in when we ran the 34. Yours will be tuned leaner than ours was, AND you'll be off the throttle more, because, well, you're a pussy. :)
But it's a family spec R34, with DVD player, kids and a dog in the back.
See how cocky I am when I'm not competing this year. :)
Ten bucks says we can beat your time over Arrowsmith in our borrowed STi Snowy :)
You going to join the service crew race though the stage :)
Yep in the ML55 (hard life aye), the cops love sitzing at service crew, when i came off in 08 a 70 series cruiser came screaming round the corner to find a tow truck accross the road. He locked all 4 up, and the she cop when off her tits.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
