piping job i just finished(all the piping anyway)
before
the "here" points to were it was rubbing with the cheap china r32 kit NOT designed for a silvia with a bloody rb20 in it.. dodgy South australians.
after
cooler mounted properly.(wish i had of got pics of how dodgily the cooler was mounted before)
new piping
and pictures of the new piping all fitted up properly.
will finish putting headlights and a different front bar on tomorow.. will more than likely put up a pic after i get it 100% back together
https://www.sau.com.au/forums/topic/228106-rb20-silvia-intercooler-piping/
what thickness piping are you using? and are you using stainless steel?
1.6mm 304 stainless is wat i generally use however on that the 2inch(hot) side of that piping is 316 due to supplier having no 304(luckily he did them for same price) and the 2.5 side(cold) is 304
i use the same stuff for all the work i di weather it be intake pipes, intercooler pipes, exhaust systems(except manifolds i'll use steam pipe when i have someone want me to amke one)
Looks good Wazz, certainly a whole lot better than the original set up :D
What are your thought for changing the piping routing like you do, is it purely for ease of set up or have you found gains/ease of use that way???
Cheers Ben
Cheers Ben
thanks dude
in the one skyline ive driven hard that ive changed from normal way to reverse it felt as there was a small gain.. the rest of them havent had aftermarket fmics on them before ive done the piping except for this silvia.. however im licenseless and its unregistered.. so i havent driven it except up the driveway to were it sits now
my theory is it gives the hot air a better chance of cooling down before it reaches the intercooler with the longer pipe and as for the cold air coming out of the intercooler its a shorter pipe so it has less chance of heat soaking as much not to mention running a pipe with supposely cool air straight across the farken radiator is bloody stupid.. its basically just common sense
thanks dude
I've had a couple of 32's and done the piping the conventional way and also the under/around set up but never really noticed any performance gains to warrant the extra piping length of the later.
Like you said you dont get the hot air like you do with the piping sitting in front of the motor with the conventional way but i've never had engine temps that extreme to justify it. So with that said im lazy and if i can buy a pre made kit cheaper than i can do it myself that only requires minimal tweaking i'll take it everytime :D
the length of the piping is the same regardless of which was you run it.. think about it with the standard setup with the alloy elbow the inlet of the elbow and outlet of the turbo are on top of each other
Might be with that set up for the silv but its not for a 32, i know for a fact cause we measured it up :banana:
Not only that but with the under/under route you actually add additional bends into the equations as well. Hindering to performance??? Some say so but like i said above i've run the piping 3 ways on my 32's and never seen or gained any improvement for overall airflow.
looks aight, but what a waste on such a p.o.s
Nice attitude! So maybe the car in the photos doesn't suit your taste, so what? What's not to say that this car is the owner's pride and joy? Or maybe it's a drift pig,or the owner wants the car to have an element of surprise, so looks are less important. Remember what (I hope) your parents taught you: If you can't say something nice, don't say anything at all...
If it was a joke, adding a smilie or "LOL" to your comment would go a long way to putting your point across - it's not as if other forum users can see you face-to-face and read your body language or facial expressions. Please take this into account in the future. Any more negative comments like this and warnings will be handed out.
omg, no need to get on your high horse, wasn't a joke. piping = good, car = rough imo, if that's the look the owner is going for. good for him. he's achieved it. you don't like my oppinion, you shouldn't be on a forum, give me a warning? wow. i find it amazing how 99% of people can say whatever they please, tell people to f**k off, get away with ripping people of etc, but i say the same, and i automatically get in the shit everytime, for whatever reason i'm always singled out, and i'm f**kin sick to death of it.
wat you said was uncalled for.. if your goin to be a wanker you can just piss off and stay out of my threads
its not my car and if it was i'd be highly offended by wat you've said. the cars a work in progress just cause its not your cup of tea doesnt give you the right to bag the shit out of it.
u get singled out coz ur post count is so low ^ everyone has to deal with it at some point, that said, cant even really see enough of the car? only looks a bit dirty under the bonnet with the original piping on, and the cuts in the front bar. even still, drift cops ftw!
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
