well story goes, took my car to epa inspection, failed because i was running too rich,
mods are as follows:
RB20DET
greddy front mount
3" front and dump
bosch 040
EVERYTHING else is standard
i replaced the o2 sensor with another 2nd hand one but was still shooting petrol out the exhaust
anyone else think of anything?
i need help as im out of ideas and its not worth going to a tuner to tune down the car so :)
any help appreciated
Edited by HI2U
https://www.sau.com.au/forums/topic/228116-car-running-rich-its-standard/
With the modifications you've performed your car is not standard, therefore it will run rich. If you want to rectify your problem you'll need to either get a piggyback, aftermarket ecu or remap your standard ecu.
I was just reading up on O2 sensors in another part of this forum cant remember where but apprarently you have to do a ecu reset after installing/changing a new sensor just disconnect the battery for a while then take it for a drive. Dont qoute me on this but do your own search for o2 sensors.
that is correct, the ecu has a memory for the afm, o2, tps, and cas,
if any of these are changed while the ecu is plugged in it will not attempt to alter any settings.
un plug the o2 sensor, then unhook the battery, stand on the brake pedal for a good minute or with the key in the ON position so as to discharge any electrical current that is still in the system(works similar to putting a security coded car stereo in the freezer over night(loses it memory).
plug the o2 sensor back in then the battery, the ecu will relearn all the signals and ignition timing and frequencey, it will run a little rough for the first 5 minutes while the ecu remaps itself, the ecu has a base map already programmed however the map is intervalled by 500 rpm and the ecu fills in the rest.
Its because of the 040. The 040 is a higher pressure pump than standard, so now your base rail pressure will be bumped up a fair bit. The way to get around this, is you need to knock the rail pressure back down to standard (or less in some cases). Get an adjustable fuel pressure reg and fuel pressure gauge; and either knock the base pressure back down to factory specs for an easy fix, or better yet find a good tuner to check AFR's with a wideband/lambda and set the pressure accordingly.
your modification to the intercooler is another reason why its running rich. it mucks up the tune and its very noticable.
my car only has a pod / fmic / exhaust and it runs AF's down to the 9.0's!
but there is an long thread by someone on here which said to have the right emissions (NOx etc) you actually had to run rich.... food for thought
I bet you have a stuffed fuel regulator :laugh:
@ idle, if you rev it and can see a bit of a fuel cloud, bets on the fuel reg.
Get a pressure gauge, hook it up, take it for a quick drive and i bet it'll be all over the place :cool:
ummm no thats not the case at all.
The fuel reg is a fuel reg, it regulates the fuel. It does not matter WHAT pump you have behind it, the factory fuel reg will hold the pressure (as long as its working)
Ive never heard as much wrong advice in a thread. Your mods should not effect your A/F ratio. There is something wrong. As nismiod said fuel reg, or possibly dirty afm(although that usually makes it lean) Do a diagnostic search, reset the ecu, comp test with new spark plugs, and check fuel pressure. Also make sure your IC piping doesn't have any leaks(although that will also make it lean at idle, rich on boost)
If the aftermarket pump is a higher pressure than the stock one(lets disregard flow rates for the moment, just concentrate on pressure), then the rail pressure will be higher. The pressure reg is vacuum controlled, therefore it does not know to compensate for higher pump pressure. It can only compensate for engine load (vacuum/mani pressure).
RB20DET
greddy front mount
3" front and dump
bosch 040
I doubt petrol was coming out the exhaust, probably just condensation.
The first thing you should do is check ignition timing, the spark has a big influence on how well the fuel burns.
NO, the pressure reg holds pressure to a preset amount above manifold pressure, regardless of the pump (as long as teh pump can keep up)
Lol fair enough mate you could be right. Its just, the way i thought of it was; if the pump is too high pressure and the reg is trying to control the base pressure by spring, at high pressure the stock reg cannot return the amount of fuel required of it to maintain its preset pressure, so it becomes a restriction. And seeing as it is now a restriction, it causes the rail pressure to rise. You could be right, but thats just the way that i see it... seeing as the 040 is a 6.5bar pump, i would have imagined it would be a significant rise over stock.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
