Recently copped an epa violation, just got tested, im 10dB over :)
Exhaust dude said if i can find the flange for my exhaust (3in 4-hole, cant seem to find anyone who can tell me where i can find one), he'll weld the new muffler onto it, and i can just bolt it off and put the old one back on after its tested.
So therein be my problem, locating this flange. Ive had a suggestion that i cut all the flanges off and put standard 2-hole flanges in. Is this advisable?
Thanks in advance for any advice or suggestions,
Nasha
https://www.sau.com.au/forums/topic/228125-epa-violation-what-to-do/
Can you get something put in it to muffle (quieten) the sound a bit?
Well in theory yeah, and i've heard of people doing this, but not exactly sure how its done. And i imagine if not done correctly its just gonna spit out whatever i stuffed in there lol. And it also means i need to goto another tester :)
Anyone have any input towards this idea also??
why dont u just locate a factory cat back? or something quiet enough. bolt it on. get it tested, pass it and then put ur old one back on.
dont go welding crap.
Thats an option i hadn't thought of funnily enough... But sadly, i dont know if my exhaust mod is cat back or turbo back (performed prior to recently purchasing). I'll take a look tomorrow and see if its a viable option
yeh do that.
regardless of if its a turbo or cat back, just replace the catback with something quiet. that way its a easy bolt on and off when u pass the test.
and if u ever run into this trouble again you can just do it again. all you need are jacks or a hoist.
yeh do that.
Im just a bit worried about this strange flange. Maybe the entire exhaust setup has these strange flanges, and i wont find anything to get onto it
the flange only applies to the muffler i believe.
catbacks all have a standardized connection these days. just take it to a local exhaust shop theyll be able to tell u wat it is.
Well thats a good start, but whats the chances of finding a catback exhaust thats cheaper than a muffler itself?
yeh do that.
Except next time you get caught for the same EPA violation its $1000's in fines.
Just replace the cat with a stock one, surly your running a 3" or bigger and its more flow the stocky doesnt flow well at all.
You may wish to look at a EPA tune too (tuned to meet epa standards)
Edited by DECIM8
Any welding shop can plasma cut a flange, all you'd need is a gasket for a template. Buy a peice of 3/8" x 5" square plate and cut it out yourself, cost $2.00 and couple of hours.
All you'd need is a pencil, center punch scribe, hammer, half round file, and a drill with a small bit.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
