ok so it was noticable tonight to post up on here, at around 4000rpm its almost like the car takes the accelerator off, cause i get a drop in revs and a back fire noise.
it only does it every now and then, but it shouldnt be doing it......
the car is stock, apart from 4inch hks dragger cat back exhaust, pod filter, super spark coil pack, nismo S-tune sparkplugs and supposedly a bigger fuel pump?
is it just a case of maybe running too rich? overflowing the car with fuel and choking it??? injectors? spark plugs? im new to the whole skyling thing so any advice much appreciated
if youy need any more info please let me know
cheers
rhys
i heard it tonite when you took off,did it in first but not in seccond??id just start with the basics like plugs first.have you checked the condition of them since you bought it?do you know what there gapped to?get a hold of some NGK copper plugs to chuck in here to see if that fixes the prob,there cheap and available from just about any where.
oh and it sure as hell didnt sound like traction control cutting in lol.sounded like you had a Bee R installed :laugh:
I'ts not knocking is it? Don't have an orange light flashing when you put the boot into it?
Otherwise its either air of fuel. I'd get your fuel flow and pressure tested, 10 minutes and say $50 at any reputable garage. At least that would eliminate fuel up to [but not including] the injectors.
no flashing lights, and no knocking i can hear from the drivers seat. im gonna drop into my mechanic tomorrow night and ask him a few questions, it does feel like a fuel issue....
jack, whats a bee R? yeh it did do it in first then i short shifted to 2nd and it was fine :s
Im guessing AFM, do a diagnostic search on the ecu and see if there are any trouble codes
thanks for the reply but im relatively new to the skyline thing, so if you could describe how i could do that? or is it left for someone with a dyno?
cheers
rhys
yep, I would look at failing fuel pump. or even fuel pump loose in tank. it's quite often very pronounced in 1st gear as you get rapid change in fuel requirement as it ramps onto boost, and the acceleration g's push all the fuel to the back of the tank too.
i think you may be right, i just taped up every coil to try that method, it has worked somewhat but now i am only getting it in 1st gear after 4000rpm when i seem to be turning??? it barely does it when going in a straight line in first....
so im leaning more towards a pump loose in the tank?? sound about right? whats my next step from here then?
cheers
rhys
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
