  • Replies 82
Posted Images
yes daughterboards and remaps are all generally fine (the purpose of a remap is to leave the code on the ecu as-is, with the exception of changing fuel, ignition etc mappings, so while its possible to bugger up the consult part of the ecu with a remap etc, its unlikely). either way, if it doesnt work for your car u can get a refund if its sent back in original condition.
Inline with GB rules about having a start & end date - this is now closed.
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
SAU is clamping down on these GB's that never occur, never end, and so on.
PM me if you have a problem. However, before you PM me think about this.
A group buy, is a group of people buying the product together to lower the price.
Buying single units here and there is not what constitutes a GROUP BUY
Thanks
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
