  • Replies 59
if you could get a quote for a s/s version to suit a r34 (would have it in a simular location to where yours is), with the speedflow fittings i would be keen. I believe you that there hasnt been any problems, i'd just rather have peice of mind when i'm booting the shit out of it, knowing that there is no way main oil lines will be leaking/popping off.
Also, could the thermostat be intergrated into the s/s line?
yeah the thermostat can still be used, just means another 4 fittings.
fair enough for wanting peace of mind, it just costs a bit more
im going to have a sus on exact pricing on monday.
how much for just the oil cooler core only ?
pm sent
would this fit a 7mgte / 7mge (from ma70 supra) also interested in speedflow fittings
yeah, it definitely fits the block.
NOW for the few people who are interested in the braided line version with speedflow fittings (blue and red anodised alloy) it will cost another 150-170 on top of each kit price. (not including the thermostat.) That is IF there are a few people who are interested in the kit with the braided line and fittings.
The braided hose itself is actually of a larger diameter also which means less restriction on the system.
So we're looking at around $550-$570 including the braided lines, speedflow fittings and thermostat?
I may be interested. Need to measure if the core will fit in the front of my Stagea somewhere.
I'm interested in an oil cooler with thermostat and speedflow fittings.
+1 definately interested in the whole lot
how many people did you need for the braided version to go ahead?
incorrect. another 4 fittings and 4 adapters are needed for the thermostat.
the kit will be 2nd to none though, with every component being the best you can get.
interested as in deposit interested?
3 deposits of say $80 will get it rolling. 1/2 week turnover.
this whole kit needs to be revised if there is CERTAINTY for the braided version with necessary fittings.
the first quote was for 3.5M of braided hose.
if you measure how much hose you require in TOTAL i can adjust kits to suit.
PLEASE DISCUSS, because the fine details are important.
I'm looking at mounting the oil cooler where the SMIC is. (Will be changed to FMIC of course) So if you could allow for that length. 3.5m should cover it I would think.
if you copied a simular length to what you have in your car, but just in braided line and the provision for the thermostat that should work well. Most people would have it in a simular location to where yours is.
You can definately add me as apart of the group of 3, as soon as 2 other people show interest in the same kit i dont mind putting $80 deposit
:P
:P
I'm sweet for a deposit too.
Hey mate,
Interetsed, but can you please confirm price for full kit, with braided lines long enough to mount on the passenger side of a 32GTR?
Whats the actual size of the core, (Dimensions)
is there any chance of buying the speedflow fittings and ss braided hose by itself?
i'm quite keen as i have a similar setup using the permacool and b&m thermostat with a sertrab core
i'm yet to be install the kit on the car,
and i have always been a little concerned about the rubber hose that is supplied kinking and then restricting the oil flow...
pm me if possible,
thanks,
greg-
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
