Hi
I am looking at upgrading from stock suspension in my R33 GTR to coilovers
Have managed to source a set of ZEAL coilovers that seems to be in pretty good nick, they are 2 way height adjustment, 6 point damper and the spring rate is 10/8
Car is mostly used for street use so I don't want it extremely stiff but I am chasing good handling but more for street use, mountain roads, and the occasional track day
Are these spring rates too stiff, too soft?
Will they be comfortable to use on the street?
Also has anyone had any experience with ZEAL coilovers, are they good and how do they compare to say TEIN?
Thanks
https://www.sau.com.au/forums/topic/229886-gtr-coilover-selection/
If the shocks are in good condition, then you can always throw softer springs in. ZEAL are Endless shocks and typically a pretty expensive shock, so cant imagine they are going to be too bad. Good quality shocks have an ability to make high spring rates feel pretty normal
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
