Guys I have a VG30DET roller bearing turbo on my motor with a Microtech and sard trigger boost controller holding 13psi, dropping off to 10.5 psi at the top of the rev range - I have maxed out at 183.1 rwkw (248rwhp), you guys should be getting heaps more power from the 2530. I am about to add a T3G garrett the Oz equivalent of the 2530 and expect 230rwkw.
I have a dyno graph if any one wants to see it
  • Replies 80
bbenny, i have had some dealings with Quick Fit in Hornsby 9476 2877... i have to say all my dealings were pleasant.
Considering the amount of ECU work they do (aftermarket, engine transplants, wiring using std looms etc etc.... they are the NSW Autronic dealer) then id be surprised f they cant do something for you.
I'm getting my PowerFC from Greenline. They always seem to have them so they either don't sell many or they have a heap of them.
Here's the quote from the Email:
APEXi Power FC RB20DET: 95,403 yen
Shipping: 2,500 yen
TOTAL: 97,903 yen AU$1271
From our experience in Australia, the import system works as follows:
Cost of products + 15% (maximum) import duties + cost of shipping + 10% GST.
Note that for some parts such as engine management, there is 0% duties and 3% for turbos.
So all up that is $1398.
bbenny - Removing the boost cut, or more correctly speaking air flow cut, is not a good idea. This cut is put in place to protect the motor. The cut happens when your AFM reaches a certain voltage.. Getting rid of this cut puts a voltage clamp on the ecu eg 4.5 V... When your car flows more air than this voltage clamp the ECU literaly has no idea how much air it is getting and can only be mapped by RPM, or putting it simply guessing. The only accurate method of mapping above this 'boost' cut is to swap for an AFM that reads a lower voltage at the same flow, Z32 for example. A Z32 AFM will read up to 300 rwkw ish quite easily. I have tried mapping using this simple boost cut method and it can easily result in detonation in light to medium throttle applications and very cold weather.
Feel free to call anytime if youd like to discuss some options?? 0411 878 961
Doc.
Yeah but you have to remember, by tricking the ECU that it is getting a lower level of air going in will cause the ECU to advance the ignition timing and lots of boost and advanced timing will cause detonation. and if i can get 300rwhp i dont want that!
thats why im considering the option of either remapped ECU with Z32 or PFC with Z32 i would love to go the PCF but its all beggining to get a bit expensive now...
As for the SAFC i think its great for minor adjustments or with the std turbo, but i just want to make sure everything is working together as best as possible... but that means $$$$ :)
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
