Another great night. Managed to slice .35 sec of my previous best to get a 14.181 @ 96.67 with a 2.162 6ft. Quite happy with that considering I was still running 36psi in the tyres, can't bring myself to let them down yet. Alot of familar faces out there too. Can't wait till the next Wed test'n'tune!
https://www.sau.com.au/forums/topic/23059-testntune-200803/
I was just comparing terminal speeds with the temperature and it show some interesting things ie;
Temperature (deg C).............Terminal Speed (mph)
17.......................................96.32
16.......................................96.67
16.......................................97.28
15.......................................97.11
14.......................................97.30
13.......................................98.08
I wonder what the KW increase is for every 1 degree drop in temperature?
https://www.sau.com.au/forums/topic/23059-testntune-200803/#findComment-494039
jlnewton: Congrats on the time buddy
We ran a 14.3 @ 98mph with a 2.254 60ft in the auto skyline.
Mods incluce 3inch tbo back, 12psi, pod, are front mount using standard cooler pipes and a pay load of 100kg also car was driven by a 17yr old. Hopefully next time out i'l be driving and get more then 2 runs. Was a very good night though. I might even have my car out. Should be tuned and Boosted. major grins then!!!!
https://www.sau.com.au/forums/topic/23059-testntune-200803/#findComment-495659
Steve, there was a V8 Brockie out there doing 12.6's at 109mph... you've got some hope yet!! BTW.. I have video footage of you efforts on my computer if you would like it ;) Very impressive! I'm guessing the misses wasn't there!! ;)
I ran a personal best last night as well of a 14.38 at 97mph. I was pretty stoked. Most people know how long I've tried to get that car below a 14.4!!! If I hadn't stuffed up the first run, I reckon it would have been lower than a 14.3.. *glares at accelorator pedal* .... I even tried one of those burnout things for the first time :burnout: ;) *hides* But I got shown up big time by a grey 180. But I've dicussed a story with MRE that I was actually driving the 180 and we swapped back cars at the stagging lights.. Ok? :uh-huh: It's "OUR" little secret!
I had fun. I decided I would go out and race it seeming all the problems are fixed at this point in time.. till something else breaks.
In the first run I raced FST32... I want to forget that run :sob: .. Don't know if he's on the forums here, but Hi!
Also, while I was sitting in the pits listening to an RB powered 180 (very sweet :drool: ) .. I heard them talking about the Skylinesaustralia forums. Was this anyone here, or was it someone we don't really know?
I had fun anyway. Wasn't such a fun day at work today with 5 hours sleep :drops dead:
https://www.sau.com.au/forums/topic/23059-testntune-200803/#findComment-495729
the reason why the times were so slow and speed was so fast was I was trying out 400R's Bridgestone 'Grid' something 205/55 16's which had been sitting in his garage for near on a year and were cheap and hard
For all the runs I started in 1st gear, I had too much spinning in 1st and 2nd gear - I resorted to practising the art of tire warming and 2nd gear race starts
After that last warm up, the tires were down to the metal band and the rest of the tread was smearing like glue - but it was well worth it!! :) :) :)
Erin - I would love to get hold of that vid off you sometime - you coming to sprints tomorrow?? I am hoping to end up running 12.8's with good road tires and after fixing boost drop 8-(
https://www.sau.com.au/forums/topic/23059-testntune-200803/#findComment-496754
yeah i went up to willowbank also. First time out at the track and i got 4 runs in total. Best was a 14.09@100mph. I am happy with that although i would like more traction 1st n 2nd but i had the best time. Very enjoyable pitty i got lined up with that chevy camaro with the big block in it which when racing me ran a 12 flat. And also a orange vk which ran a 12.8. So i was abit shamed out especially on the burnout sides of things. But i enjoyed myself alot.
https://www.sau.com.au/forums/topic/23059-testntune-200803/#findComment-497270
Originally posted by Spooks_Skyline
man, that cant be good for something! (2nd gear launches)
Oh I don't know.........my 2nd gear launch was good for a 6.3sec 60ft with an et of 19.6 at 102mph :) mind you ....I did stall it before I launched....or rather stumbled off the line
James.... forgot to post your 13.9!! how laid back can you get
Erin I'm expecting a 14.15 on your next time out
https://www.sau.com.au/forums/topic/23059-testntune-200803/#findComment-497279
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
