ey all.... i posted a few days ago about my manifold being screwed and now just discovered my external gate is screwed... the main seal is cracked and is now uselss!!!...
wondering if i could get suggestions of brands, places and so forth (within reason though monet wise )
thanks guys
https://www.sau.com.au/forums/topic/230752-external-gate/
^^ NOT a good idea.
My mate bought a Turbosmart UltraGate 38, from the US...after a days use on the dyno, the plunger jammed and was binding on the housing...and it was genuine.
Anyways Turbosmart AUS wouldnt have a bar of it, which is ridiculous, considering they are manufactured here, and we got stuck with a 100 dollar repair bill!
Turbosmart customer service is f**king shit.
Go local.
https://www.sau.com.au/forums/topic/230752-external-gate/#findComment-4053775
^^ NOT a good idea.
Go local.
thats just unlucky
i would rather spend $420 on a genuine tial, then cough up nearly $800 for one here, but thats me
https://www.sau.com.au/forums/topic/230752-external-gate/#findComment-4053784
thats just unlucky
THATS JUST STUPID $420 FOR A PEICE OF METAL THAT OPENS AND CLOSES..... IM TRYIN TO PICK UP A JUST JAP ONE....AND STILL ;S... im starting to not like my skyline anmore.. lol
https://www.sau.com.au/forums/topic/230752-external-gate/#findComment-4054444
If only it worked like that :blink: Things are priced on how much people are willing to spend, not the complexity of the device. TiAL have been making gates to a large market for a long time. If you hunt around, you can pick up a 48 unit for ~380ísh. Compare that price to local TS 45mm.
To make the whole thing easier to swallow, think about the costs of a stuck plunger at full noise.
Anywho,
how do ya go about replacing the diaphragm
Give the manufacture of your china gate a call for a new one. Pop the hate hat off, slam er in, slap it on, don't pinch it when doing it back up.
Edited by GeeTR
https://www.sau.com.au/forums/topic/230752-external-gate/#findComment-4054618
That piece of metal is probably one of the most important parts on the car.
Accurate boost control is a key to a reliable setup.
Dont modify your car if your going to go about it cheaply. It'll never workout nicely in the end
https://www.sau.com.au/forums/topic/230752-external-gate/#findComment-4054651
get a paypal account, go on ebay, get a genuine tial 44mm from the US for $420 and it will be on your door step in a week, happy days :blink:
That's what I did. Haven't put it on yet but have heard nothing but good things about TiAl gates.
https://www.sau.com.au/forums/topic/230752-external-gate/#findComment-4054789
and this is exactly why i laugh at people buying cheap shit "oh but its just a piece of metal that opens and closes"
buy quality and you get wat you pay for majority of the time
https://www.sau.com.au/forums/topic/230752-external-gate/#findComment-4055105
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
