its ineresting how many high rwkw cars are expected for this.
Brian hopes for over 12000kws out of 40 cars.
or did everyone get a little hopefull when filling out the entry form as to expected power?
I hope i havn't been overly optimistic as i've put down 250-300 (tune in a week and a half).......We all know your muppet bus puts down awsome numbers maybe you can take up some slack Dangerman.
  • Replies 281
lol
im only just above the average, is what i was getting at.
every other dyno day there is only a small handfull of cars that crack 300 rwkws.
it would be awesome if we could get 10 - 20 over that mark.
i asuming cubes is gonna thro 2 bar in to take the crown.
damn id be there if i wasnt overseas at that time, :O
lol
i think the KW rating spead is too large when i signed up i was making 210 so i clicked the 200-250 bracket and if Brian has don't the sums on the upper end of all the nominated brackets then it will quickly add up
Martin should bring the R35 down :O
my sil80 has been accepted, made it even, although i have to trailer the car to the event unless i cant get a day pass, hopefully i can, othrwise im not quite sure where to park and soforth, car is making just over 300rwkws atm on 1 bar, will be going to either 20 or 25 psi next week, will see some good figures out of it hopefully
so hopefully ill be looking at around 400rwkws, fingers crossed, not bad for a drift car
Edited by PIMPED_jzx100
lol
lol. Thats if I can source an actuator in time.
I've been waiting on Bill for a good 4weeks odd now but nothing has came of it so I'll take a trip up to MTQ and start looking interstate.
A Little O/T but Darren your 18psi actuator is it the small can or the large can? I've found a 19psi small can from MTQ which hopefully I can grab and then retune for in time.
Other wise it will be the usual 17psi and only just 300rwkw.
wat engine n mods u got there mate??
rb25/30, to much to post so that'll have to do for the moment, lol
oh screw it, here u go, got it off other site, couldnt be fk'd writing it out again, lol
RB25/30 with new chrome rings and race bearings. (using the turbo head not the shitty non vvt head)
fully rebuilt garrett 35/40 turbo
50mm external gate
stainless manifold
3" exhaust with hot dog and cannon out back (makes for a mean sound!!!)
Sard 550cc injectors
Nismo adjustable fuel pressure reg
genuine GReddy inlet plenum
80mm billet throttle body
rebuild OS Giken twin plate
brand new 52mm alloy radiator (works VERY well) with twin thermo's
tube and fin 300x600 fmic
brand new adjustable cam gears (isc)
Q45 afm
Remapped ECU by jeff from speedlab/turbo tune
shimmed R33 diff (1mm shim = locked)
G-MAX 18x9.5 wheels all round (not the white wheels seen in pics)
tien HE coilovers
just jap rear camber arms
race bucket seat
momo steering wheel
HKS EVC 3
speco boost, oil pressure, and water temp gauge's.
autogauge monster techo with shift light (just needs to be hooked up)
uras rear bar, origin agressive skirts (old style i have been told) yes it does have a front bar, but no pics with it on sorry, cant member what brand though
why dont u just go a externalgate set up?? or are you still running standard manifold??
hey Cubes when you put a rb30 bottom end in did you have to notify regency or is it illegal and needs to be engineered?
i was thinkn doin a similar rb25/30 build like yours after sum 1 blew my motor up but was worried bout regency
Still running std manifold. GT30r is a waste on a nice exh manifold and ext gate setup.
Unless I were to go 380rwkw+ and a GT40+ I'll stick with int gate.
yeh ive just upgraded from a gt30 on a external manifold n gate
ill be now running a gt 35/40.82 but on a custom 6boost low mount manifold
yeah i got the 35/40 .82 aswell, on lowmount, going to highmount soon though, runs really well actually, only problem with mine is u dont hear any boost whistle due to the screamer going off its tits, lol, bloody loud thing it is
i just love scaring people with it..lol
cant believe u just run a remapped ecu with all ya mods....thats` awesome
Ken/PIMPED, 400rwkw using 550cc Sard injectors... that's what i call pushing the limit!
I'm going to do my best to make it to this dyno day, as it sounds really interesting. It'll also be interesting to do a rough comparison (power curve, peak values, turbo response etc.) with my own dyno runs on Shaun's dyno - there's about 90+ of them saved on the thing ha-ha.
I might even have the tuning finished by then and could try and help bolster the import figures - I 'may' be able to offer low 300's at the rears - best of 302rwkw so far. It might squeeze out 315-320ish once the cams are set-up and a few more pounds wound in.
What we - the import team - really needs is for Darren's R31 to be up and running - 550rwkw would help push the total up nicely.
Reading all this has got me thinking that i should try to get my turbos on before this event so i can get over the 300kw mark aswell. I'll make some calls tomorrow and see what i can organise :)
umm that would be nice to see/hear chad
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
