its ineresting how many high rwkw cars are expected for this.
Brian hopes for over 12000kws out of 40 cars.
or did everyone get a little hopefull when filling out the entry form as to expected power?
I hope i havn't been overly optimistic as i've put down 250-300 (tune in a week and a half).......We all know your muppet bus puts down awsome numbers maybe you can take up some slack Dangerman.
  • Replies 281
lol
im only just above the average, is what i was getting at.
every other dyno day there is only a small handfull of cars that crack 300 rwkws.
it would be awesome if we could get 10 - 20 over that mark.
i asuming cubes is gonna thro 2 bar in to take the crown.
damn id be there if i wasnt overseas at that time, :O
lol
i think the KW rating spead is too large when i signed up i was making 210 so i clicked the 200-250 bracket and if Brian has don't the sums on the upper end of all the nominated brackets then it will quickly add up
Martin should bring the R35 down :O
my sil80 has been accepted, made it even, although i have to trailer the car to the event unless i cant get a day pass, hopefully i can, othrwise im not quite sure where to park and soforth, car is making just over 300rwkws atm on 1 bar, will be going to either 20 or 25 psi next week, will see some good figures out of it hopefully
so hopefully ill be looking at around 400rwkws, fingers crossed, not bad for a drift car
Edited by PIMPED_jzx100
lol
lol. Thats if I can source an actuator in time.
I've been waiting on Bill for a good 4weeks odd now but nothing has came of it so I'll take a trip up to MTQ and start looking interstate.
A Little O/T but Darren your 18psi actuator is it the small can or the large can? I've found a 19psi small can from MTQ which hopefully I can grab and then retune for in time.
Other wise it will be the usual 17psi and only just 300rwkw.
wat engine n mods u got there mate??
rb25/30, to much to post so that'll have to do for the moment, lol
oh screw it, here u go, got it off other site, couldnt be fk'd writing it out again, lol
RB25/30 with new chrome rings and race bearings. (using the turbo head not the shitty non vvt head)
fully rebuilt garrett 35/40 turbo
50mm external gate
stainless manifold
3" exhaust with hot dog and cannon out back (makes for a mean sound!!!)
Sard 550cc injectors
Nismo adjustable fuel pressure reg
genuine GReddy inlet plenum
80mm billet throttle body
rebuild OS Giken twin plate
brand new 52mm alloy radiator (works VERY well) with twin thermo's
tube and fin 300x600 fmic
brand new adjustable cam gears (isc)
Q45 afm
Remapped ECU by jeff from speedlab/turbo tune
shimmed R33 diff (1mm shim = locked)
G-MAX 18x9.5 wheels all round (not the white wheels seen in pics)
tien HE coilovers
just jap rear camber arms
race bucket seat
momo steering wheel
HKS EVC 3
speco boost, oil pressure, and water temp gauge's.
autogauge monster techo with shift light (just needs to be hooked up)
uras rear bar, origin agressive skirts (old style i have been told) yes it does have a front bar, but no pics with it on sorry, cant member what brand though
why dont u just go a externalgate set up?? or are you still running standard manifold??
hey Cubes when you put a rb30 bottom end in did you have to notify regency or is it illegal and needs to be engineered?
i was thinkn doin a similar rb25/30 build like yours after sum 1 blew my motor up but was worried bout regency
Still running std manifold. GT30r is a waste on a nice exh manifold and ext gate setup.
Unless I were to go 380rwkw+ and a GT40+ I'll stick with int gate.
yeh ive just upgraded from a gt30 on a external manifold n gate
ill be now running a gt 35/40.82 but on a custom 6boost low mount manifold
yeah i got the 35/40 .82 aswell, on lowmount, going to highmount soon though, runs really well actually, only problem with mine is u dont hear any boost whistle due to the screamer going off its tits, lol, bloody loud thing it is
i just love scaring people with it..lol
cant believe u just run a remapped ecu with all ya mods....thats` awesome
Ken/PIMPED, 400rwkw using 550cc Sard injectors... that's what i call pushing the limit!
I'm going to do my best to make it to this dyno day, as it sounds really interesting. It'll also be interesting to do a rough comparison (power curve, peak values, turbo response etc.) with my own dyno runs on Shaun's dyno - there's about 90+ of them saved on the thing ha-ha.
I might even have the tuning finished by then and could try and help bolster the import figures - I 'may' be able to offer low 300's at the rears - best of 302rwkw so far. It might squeeze out 315-320ish once the cams are set-up and a few more pounds wound in.
What we - the import team - really needs is for Darren's R31 to be up and running - 550rwkw would help push the total up nicely.
Reading all this has got me thinking that i should try to get my turbos on before this event so i can get over the 300kw mark aswell. I'll make some calls tomorrow and see what i can organise :)
umm that would be nice to see/hear chad
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
