its ineresting how many high rwkw cars are expected for this.
Brian hopes for over 12000kws out of 40 cars.
or did everyone get a little hopefull when filling out the entry form as to expected power?
I hope i havn't been overly optimistic as i've put down 250-300 (tune in a week and a half).......We all know your muppet bus puts down awsome numbers maybe you can take up some slack Dangerman.
  • Replies 281
lol
im only just above the average, is what i was getting at.
every other dyno day there is only a small handfull of cars that crack 300 rwkws.
it would be awesome if we could get 10 - 20 over that mark.
i asuming cubes is gonna thro 2 bar in to take the crown.
damn id be there if i wasnt overseas at that time, :O
lol
i think the KW rating spead is too large when i signed up i was making 210 so i clicked the 200-250 bracket and if Brian has don't the sums on the upper end of all the nominated brackets then it will quickly add up
Martin should bring the R35 down :O
my sil80 has been accepted, made it even, although i have to trailer the car to the event unless i cant get a day pass, hopefully i can, othrwise im not quite sure where to park and soforth, car is making just over 300rwkws atm on 1 bar, will be going to either 20 or 25 psi next week, will see some good figures out of it hopefully
so hopefully ill be looking at around 400rwkws, fingers crossed, not bad for a drift car
Edited by PIMPED_jzx100
lol
lol. Thats if I can source an actuator in time.
I've been waiting on Bill for a good 4weeks odd now but nothing has came of it so I'll take a trip up to MTQ and start looking interstate.
A Little O/T but Darren your 18psi actuator is it the small can or the large can? I've found a 19psi small can from MTQ which hopefully I can grab and then retune for in time.
Other wise it will be the usual 17psi and only just 300rwkw.
wat engine n mods u got there mate??
rb25/30, to much to post so that'll have to do for the moment, lol
oh screw it, here u go, got it off other site, couldnt be fk'd writing it out again, lol
RB25/30 with new chrome rings and race bearings. (using the turbo head not the shitty non vvt head)
fully rebuilt garrett 35/40 turbo
50mm external gate
stainless manifold
3" exhaust with hot dog and cannon out back (makes for a mean sound!!!)
Sard 550cc injectors
Nismo adjustable fuel pressure reg
genuine GReddy inlet plenum
80mm billet throttle body
rebuild OS Giken twin plate
brand new 52mm alloy radiator (works VERY well) with twin thermo's
tube and fin 300x600 fmic
brand new adjustable cam gears (isc)
Q45 afm
Remapped ECU by jeff from speedlab/turbo tune
shimmed R33 diff (1mm shim = locked)
G-MAX 18x9.5 wheels all round (not the white wheels seen in pics)
tien HE coilovers
just jap rear camber arms
race bucket seat
momo steering wheel
HKS EVC 3
speco boost, oil pressure, and water temp gauge's.
autogauge monster techo with shift light (just needs to be hooked up)
uras rear bar, origin agressive skirts (old style i have been told) yes it does have a front bar, but no pics with it on sorry, cant member what brand though
why dont u just go a externalgate set up?? or are you still running standard manifold??
hey Cubes when you put a rb30 bottom end in did you have to notify regency or is it illegal and needs to be engineered?
i was thinkn doin a similar rb25/30 build like yours after sum 1 blew my motor up but was worried bout regency
Still running std manifold. GT30r is a waste on a nice exh manifold and ext gate setup.
Unless I were to go 380rwkw+ and a GT40+ I'll stick with int gate.
yeh ive just upgraded from a gt30 on a external manifold n gate
ill be now running a gt 35/40.82 but on a custom 6boost low mount manifold
yeah i got the 35/40 .82 aswell, on lowmount, going to highmount soon though, runs really well actually, only problem with mine is u dont hear any boost whistle due to the screamer going off its tits, lol, bloody loud thing it is
i just love scaring people with it..lol
cant believe u just run a remapped ecu with all ya mods....thats` awesome
Ken/PIMPED, 400rwkw using 550cc Sard injectors... that's what i call pushing the limit!
I'm going to do my best to make it to this dyno day, as it sounds really interesting. It'll also be interesting to do a rough comparison (power curve, peak values, turbo response etc.) with my own dyno runs on Shaun's dyno - there's about 90+ of them saved on the thing ha-ha.
I might even have the tuning finished by then and could try and help bolster the import figures - I 'may' be able to offer low 300's at the rears - best of 302rwkw so far. It might squeeze out 315-320ish once the cams are set-up and a few more pounds wound in.
What we - the import team - really needs is for Darren's R31 to be up and running - 550rwkw would help push the total up nicely.
Reading all this has got me thinking that i should try to get my turbos on before this event so i can get over the 300kw mark aswell. I'll make some calls tomorrow and see what i can organise :)
umm that would be nice to see/hear chad
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
