its ineresting how many high rwkw cars are expected for this.
Brian hopes for over 12000kws out of 40 cars.
or did everyone get a little hopefull when filling out the entry form as to expected power?
I hope i havn't been overly optimistic as i've put down 250-300 (tune in a week and a half).......We all know your muppet bus puts down awsome numbers maybe you can take up some slack Dangerman.
  • Replies 281
lol
im only just above the average, is what i was getting at.
every other dyno day there is only a small handfull of cars that crack 300 rwkws.
it would be awesome if we could get 10 - 20 over that mark.
i asuming cubes is gonna thro 2 bar in to take the crown.
damn id be there if i wasnt overseas at that time, :O
lol
i think the KW rating spead is too large when i signed up i was making 210 so i clicked the 200-250 bracket and if Brian has don't the sums on the upper end of all the nominated brackets then it will quickly add up
Martin should bring the R35 down :O
my sil80 has been accepted, made it even, although i have to trailer the car to the event unless i cant get a day pass, hopefully i can, othrwise im not quite sure where to park and soforth, car is making just over 300rwkws atm on 1 bar, will be going to either 20 or 25 psi next week, will see some good figures out of it hopefully
so hopefully ill be looking at around 400rwkws, fingers crossed, not bad for a drift car
Edited by PIMPED_jzx100
lol
lol. Thats if I can source an actuator in time.
I've been waiting on Bill for a good 4weeks odd now but nothing has came of it so I'll take a trip up to MTQ and start looking interstate.
A Little O/T but Darren your 18psi actuator is it the small can or the large can? I've found a 19psi small can from MTQ which hopefully I can grab and then retune for in time.
Other wise it will be the usual 17psi and only just 300rwkw.
wat engine n mods u got there mate??
rb25/30, to much to post so that'll have to do for the moment, lol
oh screw it, here u go, got it off other site, couldnt be fk'd writing it out again, lol
RB25/30 with new chrome rings and race bearings. (using the turbo head not the shitty non vvt head)
fully rebuilt garrett 35/40 turbo
50mm external gate
stainless manifold
3" exhaust with hot dog and cannon out back (makes for a mean sound!!!)
Sard 550cc injectors
Nismo adjustable fuel pressure reg
genuine GReddy inlet plenum
80mm billet throttle body
rebuild OS Giken twin plate
brand new 52mm alloy radiator (works VERY well) with twin thermo's
tube and fin 300x600 fmic
brand new adjustable cam gears (isc)
Q45 afm
Remapped ECU by jeff from speedlab/turbo tune
shimmed R33 diff (1mm shim = locked)
G-MAX 18x9.5 wheels all round (not the white wheels seen in pics)
tien HE coilovers
just jap rear camber arms
race bucket seat
momo steering wheel
HKS EVC 3
speco boost, oil pressure, and water temp gauge's.
autogauge monster techo with shift light (just needs to be hooked up)
uras rear bar, origin agressive skirts (old style i have been told) yes it does have a front bar, but no pics with it on sorry, cant member what brand though
why dont u just go a externalgate set up?? or are you still running standard manifold??
hey Cubes when you put a rb30 bottom end in did you have to notify regency or is it illegal and needs to be engineered?
i was thinkn doin a similar rb25/30 build like yours after sum 1 blew my motor up but was worried bout regency
Still running std manifold. GT30r is a waste on a nice exh manifold and ext gate setup.
Unless I were to go 380rwkw+ and a GT40+ I'll stick with int gate.
yeh ive just upgraded from a gt30 on a external manifold n gate
ill be now running a gt 35/40.82 but on a custom 6boost low mount manifold
yeah i got the 35/40 .82 aswell, on lowmount, going to highmount soon though, runs really well actually, only problem with mine is u dont hear any boost whistle due to the screamer going off its tits, lol, bloody loud thing it is
i just love scaring people with it..lol
cant believe u just run a remapped ecu with all ya mods....thats` awesome
Ken/PIMPED, 400rwkw using 550cc Sard injectors... that's what i call pushing the limit!
I'm going to do my best to make it to this dyno day, as it sounds really interesting. It'll also be interesting to do a rough comparison (power curve, peak values, turbo response etc.) with my own dyno runs on Shaun's dyno - there's about 90+ of them saved on the thing ha-ha.
I might even have the tuning finished by then and could try and help bolster the import figures - I 'may' be able to offer low 300's at the rears - best of 302rwkw so far. It might squeeze out 315-320ish once the cams are set-up and a few more pounds wound in.
What we - the import team - really needs is for Darren's R31 to be up and running - 550rwkw would help push the total up nicely.
Reading all this has got me thinking that i should try to get my turbos on before this event so i can get over the 300kw mark aswell. I'll make some calls tomorrow and see what i can organise :)
umm that would be nice to see/hear chad
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
