  • Replies 281
it's ok i got a fantastic mechanic! anyway what brand are they?
OEM Mazda 550cc. Happily supporting 300+rwkw on my RB25DET at the moment, and up until ~17th Nov 08. Then out they come and in go the 780's.
^ bump ^
We've had a couple cars pull out due to engine trouble, not ready or being upgraded on the day of the dyno.
If your interested in running on the dyno we need you!
Domestics are only 2 cars short, however we are still accepting entries from higher power cars also.
Entries officially close on the 14th on November.
Cost is $30.
Date: 22nd November.
Time: 10AM till 5PM.
Apply here:
http://toyotacarclub.net/events/domvsimp/
Thanks guys!
I'm interested. However, my car will be undergoing a few minor upgrades at Boostworx around the 17th-20th of this month, and although it 'may' be ready in time, I won't really know until after the close date - the car could even still be there when the dyno day is on.
^ bump ^
Cost is $30.
Apply here:
Thanks guys!
can you post up bank details i cant seem to find the email
Me but i dont think i will get my new pfc in, in time i was ment to pick it up today but the guy couldnt meet me and now he is express posting from milicent or round that way, then i have to see if Shaun can wire it up as its a GTR pfc
Sorry Matt, I'm just reading this.... didn't it do that a couple years ago???
Hope to catch you soon!
Ha-ha fair call, Will :( What can I say, it started as a simple $3k turbo upgrade in 2006 and has since turned into a... ummm... maybe $10k long term project. The old set-up that ran the numbers listed in my sig' is not even close to the 'real world' grunt of the new set-up, and the new set-up isn't at full potential yet. At best I reckon the old set-up would've made 260-270rwkw on the BW dyno.
Unfortunately it won't be ready for the dyno day on Sat, so I'll merely be a spectator. Be good to catch up though mate.
it will work madaz, i got a gtr pfc in my r33 gtst
im thinkin of coming to watch/support the japs
im goin on a fishing/drinking trip friday night so not sure what sort on condition ill be in :)
chris, steve has GTS4t, maybe i little different.
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
