  • Replies 281
it's ok i got a fantastic mechanic! anyway what brand are they?
OEM Mazda 550cc. Happily supporting 300+rwkw on my RB25DET at the moment, and up until ~17th Nov 08. Then out they come and in go the 780's.
^ bump ^
We've had a couple cars pull out due to engine trouble, not ready or being upgraded on the day of the dyno.
If your interested in running on the dyno we need you!
Domestics are only 2 cars short, however we are still accepting entries from higher power cars also.
Entries officially close on the 14th on November.
Cost is $30.
Date: 22nd November.
Time: 10AM till 5PM.
Apply here:
http://toyotacarclub.net/events/domvsimp/
Thanks guys!
I'm interested. However, my car will be undergoing a few minor upgrades at Boostworx around the 17th-20th of this month, and although it 'may' be ready in time, I won't really know until after the close date - the car could even still be there when the dyno day is on.
^ bump ^
Cost is $30.
Apply here:
Thanks guys!
can you post up bank details i cant seem to find the email
Me but i dont think i will get my new pfc in, in time i was ment to pick it up today but the guy couldnt meet me and now he is express posting from milicent or round that way, then i have to see if Shaun can wire it up as its a GTR pfc
Sorry Matt, I'm just reading this.... didn't it do that a couple years ago???
Hope to catch you soon!
Ha-ha fair call, Will :( What can I say, it started as a simple $3k turbo upgrade in 2006 and has since turned into a... ummm... maybe $10k long term project. The old set-up that ran the numbers listed in my sig' is not even close to the 'real world' grunt of the new set-up, and the new set-up isn't at full potential yet. At best I reckon the old set-up would've made 260-270rwkw on the BW dyno.
Unfortunately it won't be ready for the dyno day on Sat, so I'll merely be a spectator. Be good to catch up though mate.
it will work madaz, i got a gtr pfc in my r33 gtst
im thinkin of coming to watch/support the japs
im goin on a fishing/drinking trip friday night so not sure what sort on condition ill be in :)
chris, steve has GTS4t, maybe i little different.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
