I'm Goin For A Drive *sunday 7th September*
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 186
Posted Images
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
11. Michele & Mark - I'll just have to bring a photo of the open wheeler so she doesn't feel left out.
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
17. TURISMO (is gay)
18. naughtyruski
19. SteadyEddie
20. a20089 (for even numbers sake)
21. Kat
22. bnr32t (only if it rains, good drift weather)
Edited by BNR32t
it's cos you spell his name wrong
well since like EVERYONE is going I dont want to feel left out so I might as well come too :)
warning: I will be tired and grumpy on a few hours sleep so dont piss me off hehe
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
18. naughtyruski
19. SteadyEddie
21. Kat
23. Shell
1. Tarmac-
2. Ex!$t3nZ
3. Bluprint
4. datto260Z
5. Gus-
6. CeJay
7. INVRTD
8. Frink & Bullet32
9. Sky33t
10. zcr
13. TiTAN
12. Mccreddy
14. Stunnd
15. GT-5732
16. Baconer
18. naughtyruski
19. SteadyEddie
21. Kat
23. Shell
24. Sl33py (said he was interested)
Im starting to think you dont like me Kieth
LoL, well you did spell my name wrong...
I was told to kick you the other day... lol. (something to do with your rims)
PS. bring on the motorkahana... :whistling: This time i have the poor tyres.
haha, finally had a look at the route. Should be hilarious with the 28, i literally cannot accelerate up hills in any gear above 2nd... Probably best if i sit at the back, also theres that whole Toyota thing aswell :whistling:
So there is a chance someone will get done for speeding? Serious??? :P
Goddamnit.... :D i have enough problems with defects and D's following me to worry about!! I just had yet another Dickson inspection again...
Can't say for sure what chicks go through with a gynaecologist, but i felt violated.. :)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
