I'm Goin For A Drive *sunday 7th September*
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 186
Posted Images
i think the everyone bringing their own food is the way to go. saves people complaining if they dont like whats on offer, also saves someone getting stuck with left over food as kat said.
i will still be there if its raining.. i will just drive a little slower :banana:
Me and Suzz will be along for the cruise...cheese, wine and old school hip hop.
I made the front page of the Canberra times today :3some: so thats what I look like if you go ..ahh I know him..
Also, I have 3 walkie talkies if you want me to bring those along to ? for the lead, middle and rear cars....or not that organised ? don't mind either way.
Guys and Gals
I dont think I'll make tomorrow....dont really feel up to it after Friday morning :3some:
Also, driving is a little bit annoying ATM...so the less I do, the better......
Nice quient cruise, thanks for letting us tag along Tarmac.
LOL quiet.
Thanks for today guys, lots of fun! Was nice to meet everyone! Now to try and work out who owns what and who is who..... :/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
