98 Skyline GTT NEO with following mods
Rb30 block crack and pressure tested, honed etc
crank nitrided
Argo rods
Cp 20 thou pistons ceramic coated
ACL bearings
Fully balanced
main studs
Jun oil pump/crank collar
N1 water pump
H.E sump
ati balancer
NEO head
Fully recon
port/polished and matched to inlet/exhaust manifold
gtr tomei 260 poncams/cam gears
performance wise springs/retainers
1000cc sards
hks gtr rail
head studs
oil restrictors
greddy plenum
q45 tb
6boost manifold
t04z (1.00)
48mm progate
ARE intercooler
greddy radiator
splitfires
HKS twin ignition
NPC twin clutch
haltech e11
x2 044
NOS kit
braided fuel lines underneath car
etc
Will post more pics this week. Power goal of 620rwhp and 700 with nos
Edited by drgnball34
https://www.sau.com.au/forums/topic/230963-rb2530-neo/
  • Replies 90
very good tyres and suspension tweaks...anything to help i guess but your right about spin city. Have you seen the 800rwhp+ supras going around in the usa on youtube? Hell they even got 1000hp beasts! I wont even bother launching the thing its pointless. Maybe roll ons on the freeway from 3rd gear :P
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4064605
sounds like a mean build. What are the specs of your pistons? im using JE flat top pistons, but im worried about what the compression ratio is going to be. what is your dish/dome and deck clearance?
I just picked up my NEO head so ill be finding the CC of the chambers once i clean them and get a syringe and perspex :thumbsup: but i had a rough measure using a CD and measuring spoons and they look around 56cc.
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4083264
CD and measuring spoon LOL, i love it. Im pretty sure thats about what i measures mine at. The flet top Pistons should work about right, thats what im using for my 25/30 NEO, and deending what the final measurements are, i could adjust the comp from about 8.4:1 to 9.2:1 depnding on th eheadgasket used
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4083714
yea well im hoping they will be sweet. I initially got them custom made to suit vg30 rods for a better rod/stroke ratio but i was going to use them with an R32 RB25DE head i had. they have a bit of deck clearance so i have room to deck the head if need be as well as play round with gasket thickness, so i dont think it will be a problem :blink: . also, since i got custom cams made (276 10.5mm lift) for the r32 head, i figured that to run them in the r34 head im going to need to run the r32 CAS, and im not going to run vvt, just block up the oil feed hole
also, just out of interest, i thort r34 heads had bigger valves but they look the same as my r32 head. again i dont have proper measuring tools on me im gona bring them home from work on the weekend to suss everythin out
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4085828
I heard that the exhaust valves are bigger then the rb26's. They actually used r33 cp pistons which gave a higher comp ratio on the Neo head. But all technical aspects I would need to talk to the builder as my mechanical knowledge is little. It was pretty much drop my car off and let the workshop do their magic.
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4087754
you wont be able to run those cams in the NEO head, the lift is too big.
yea well im hoping they will be sweet. I initially got them custom made to suit vg30 rods for a better rod/stroke ratio but i was going to use them with an R32 RB25DE head i had. they have a bit of deck clearance so i have room to deck the head if need be as well as play round with gasket thickness, so i dont think it will be a problem :( . also, since i got custom cams made (276 10.5mm lift) for the r32 head, i figured that to run them in the r34 head im going to need to run the r32 CAS, and im not going to run vvt, just block up the oil feed hole
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4088146
Is that r33 rb25 or r33 rb26 pistons they have used ??
If it is either, youll need to run some serious race fuel as your comp is going to be over 10 to 1
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4088148
These NEO heads are really interesting and WAY different to any other rb25 head.
Hey Spoolup, do you mean I cant run the cams Ive got? I know they dont direct fit, ive had to grind a tiny bit off where the lobe catches the head around the edge of the lifter. BUT, in the R32 head i wuld have had to cut shitloads out but in this head i only had to cut a little bit. Maby this is partly because the Neo Buckets are wider diameter than r33 lifters, and a totally different design even to the gtr lifters. so far so good. the other thing is te shims in the Neo buckets are exactly the same diameter as Subaru shims, so thats a cheap alternative I used to get the clearance on my cams right coz theyre way more common to find
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4089037
Yes they are a great head.
Just install your cams and turn the cam until you have a valve at maximum lift, then check your lifter and see if the oil gallery that runs along the lifters ( inside the head ) is exposed. If so you can not use them as you will never get oil pressure.
With my setup anything over 9.8mm lift exposed the oil gallery.
Im in the process of building a new head and trying to get around this my using small base cirlce cams and tipping the valves ( extending them )
Cheers
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4090057
The tips of each valve is built up a little with weld - they are then ground to the determined length. Its cheaper than 24 custom valves.
With aftermarket springs there is enough room to run up to 12mm lift with out the springs binding - its just the oil gallery issue that needs to be resolved.
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4090250
ok, it seems your right but i think i have a plan. Im gona use gtr retainers and shims as they shim from underneath, so that will imitate the tipping your talking about. then, ill have to find some springs thatll be suitable or get some made, that shuldnt be too much of a prob. wat do ya think wise one?
https://www.sau.com.au/forums/topic/230963-rb2530-neo/#findComment-4093784
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
