Hot topic at the moment, lots of ramifications for those who are seen at the wrong place: husband cheating on wife, worker caught sleeping in van during working hours, men outside sexy land stores, cars parked at brothels etc...
Post your interesting finds !!
https://www.sau.com.au/forums/topic/231148-google-maps-streetview/
  • Replies 79
Posted Images
Okay so I was looking at my work and decided to have an explore further down my street (Vale St)... look at the corner of Vale St and Greeves St...where the hookers stand... now that is funny lol
Ah, so it's your 33 I see parked at the end of that street.
lol for Grant!
never mind all the visual, look at this sht!
Driving directions to Byron Bay NSW, Australia
10,541 mi – about 42 days 12 hours
Springfield, IL
1. Head north on I-55-BL toward E Washington St
210 ft
2. Turn right at E Washington St
0.2 mi
3. Turn left at N 12th St
0.2 mi
4. Slight right at IL-29 S
1.7 mi
5. Continue on IL-97 E
0.6 mi
6. Take the exit onto I-55 N/I-72 E toward Chicago
0.3 mi
7. Continue on I-55 N
29.2 mi
8. Continue on I-155 N (signs for Hartsburg/Peoria/I-155 N)
32.0 mi
9. Take the exit onto I-74 W toward Peoria
87.4 mi
10. Continue on I-80 W
Entering Iowa
186 mi
11. Continue on I-35 S
7.1 mi
12. Take the exit onto I-80 W toward Council Bluffs/Omaha
95.2 mi
13. Take exit 27 to merge onto I-680 W toward N Omaha/Sioux City
16.6 mi
14. Take exit 13B to merge onto I-29 N toward Sioux City
Entering South Dakota
164 mi
15. Take exit 84B to merge onto I-90 W toward Rapid City
Passing through Wyoming
Entering Montana
702 mi
16. Take the exit onto I-90 W toward Billings
Passing through Idaho
Entering Washington
823 mi
17. Take exit 2C to merge onto I-5 N
2.0 mi
18. Take exit 167 on the left toward Seattle Center
0.7 mi
19. Turn right at Fairview Ave N
400 ft
20. Turn left at Valley St
0.2 mi
21. Turn right at Westlake Ave N
1.6 mi
22. Turn right at 4th Ave N
0.3 mi
23. Turn right at N 34th St
0.3 mi
24. Turn right at Stone Way N
112 ft
25. Turn left at N Northlake Way
0.3 mi
26. Kayak across the Pacific Ocean
Entering Australia (New South Wales)
7,906 mi
27. Sharp right at Macquarie St
0.4 mi
28. Turn right at Albert St
289 ft
29. Turn left at Phillip St
0.1 mi
30. Turn left at Bridge St
305 ft
31. Turn left at Macquarie St
144 ft
32. Turn left to merge onto Cahill Expy
0.7 mi
33. Exit onto Bradfield Hwy
1.0 mi
34. Slight left to stay on Bradfield Hwy
0.3 mi
35. Continue on Warringah Fwy
2.9 mi
36. Continue on Gore Hill Fwy
0.7 mi
37. Exit on the right onto Pacific Hwy
0.3 mi
38. Turn right to stay on Pacific Hwy
8.5 mi
39. Turn right to merge onto Sydney Newcastle Fwy
78.9 mi
40. At the roundabout, take the 3rd exit onto John Renshaw Dr
0.4 mi
41. Take the ramp onto New England Hwy
2.8 mi
42. Slight left to stay on New England Hwy
0.3 mi
43. Slight left at Pacific Hwy
Go through 1 roundabout
19.4 mi
44. Continue on Karuah Bypass
6.3 mi
45. Continue on Pacific Hwy
25.8 mi
46. Slight left at Bulahdelah Coolongolook Fwy
13.6 mi
47. Continue on Pacific Hwy
Go through 2 roundabouts
216 mi
48. Turn right at Centenary Dr
2.7 mi
49. Turn right at Pacific Hwy
78.3 mi
50. At the roundabout, take the 1st exit and stay on Pacific Hwy
0.9 mi
51. At the roundabout, take the 1st exit and stay on Pacific Hwy
14.7 mi
52. Turn right at Bangalow Rd
5.6 mi
53. Turn left to stay on Bangalow Rd
1.3 mi
54. Turn left at Browning St
0.1 mi
55. Browning St turns right and becomes Jonson St
0.5 mi
Byron Bay NSW
Australia
i know its a lot, but the section in bold is what u want
type in Byron bay, then get directions to byron bay from springfield
and observe!
Edited by RusH_
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
