  • Replies 79
Posted Images
yay i found my car. first i checked home and no cars were there, so i tried my work and i found it in the parking lot, i couldn't believe it i didnt think i would find it but its pretty much by itself. carpark wasnt very full. its not a very clear pic cause you have to zoom in from the road to see the carpark but its definately mine.
found my place, the data seems to be from around nov 07.
It varies, i looked at a few places - the one of my beachhouse has a friends car out the front, she didn't get there until late dec.
And another place on the other side of the state has a path i built in it early january shown pretty clearly.
Edited by baron25
GTIRR - Andrew found his wife carrying shopping and Flash found his overweight dog in the driveway.
Saff - Barge from the carpark next door parked out the front of the apartment.
says the man with the slippery couch tacos
i went to my gf's house and saw someone (hard to see who) in her front yard.. so i msgd her saying "aha i looked on google maps at your house" etc etc
and she replies
"oh no! no ones home today im so worried!!!"
:P
people shouldnt really put their address on their online resume's - too easy to keep track of their house now...
Why? it's not like the photos are in real time...The streetview photo of my house is almost a year old and the satellite photo is over 3....
The photos were taken over a 6 month period...
Pretty sure there still going aren't they? saw one of the cars the other day.
Found a few skylines round my area too :woot: and somebody gettin in their car round the corner :P
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
