New Here
MissDee
 Share
  • Replies 125
Posted Images
well, if it's worth MY while then I'm sure there's a flight tomorrow.....But I would have to tow the car, would that work??
be careful :P it's always the MINGERS who ask for it..... the hot ones just get it :P
lol did I just offend 2 ppl at once? Woo new record. and on that note...catchas
Nah,. I just have a reputation...... :P
Oh no sweety I wasn't talk about you hahahaha
:laughing-smiley-014:
Guys all have reputations..... girls should attempt to get a reputation. Charisma and charm should come naturally lol
Actually no, I take that as a compliment, cos I've never had to ask for it...
What ever "it" may be....haha
CYA
Hey just trying to have a laugh, nothing serious.
Not desparate, just teasin!
its just sketchy when a chick signs up to a car forum and then within a day is "teasing" before making any actual buddies
no harm :P I'm just saying what everyone else is thinking
It's all just fun and games.........
People who take everything serious are very tense people......with grey hair!
Nice Tats by the way! I've been "deciding" what to get for about 10 yrs...
Yeah make sure ur 100% sure bout what you want and who u want to do it.
Thank god i dont have grey then.
You realise the only reason this thread has become such a huge welcome is because you're a girl right.
If I had to say, "hi, I'm new here" when I joined, one or two guys might say pfft lol
Anyway... welcome. Have a great stay :P Everyone hangs out in WT. I'm sure we'll see you there :P
Anyway... welcome. Have a great stay :google: Everyone hangs out in WT. I'm sure we'll see you there :down:
Yeah i kinda figured that.
Hey girl or guy, its nice to see new members.
 Share
    • Any chance you can get a Nistune board installed instead and set the speed limit to whatever your tires can handle?
    • Hi all, I need to get this HKS SLD attached to my stock ECU because I've now got the German autobahn and faster European circuits to contend with.  The car is a manual 2dr ER34 with an AT ECU and I've realised the AT ECU has two pins for speed sensor signals: Pin 29: Vehicle speed sensor signal (Vehicle speed sensor 2) Pin *58: Output shaft rotation sensor signal (Vehicle speed sensor 1) - *RB25DET A/T model only Before I go butchering this harness, is anyone sure of which pin is the correct one for signal adjustment? The attached document from HKS indicates pin 29 but I found this situation mentioned in the following thread on a different forum (R34 GTT Auto Trans Speed Cut Problem | Zerotohundred) mentioning pin 58 needing to be altered by member zephuros, albeit it seems to be for an RSM-GP and the info appears to be old.  R34_All_Workshop_Manual-pages-2.pdf R34_All_Workshop_Manual-pages-3.pdf R34_All_Workshop_Manual-pages-1.pdf HKS SLD Vehicle Pin out P59-P70 ER34-pages.pdf
    • Slimline sub on the rear parcel shelf is doable. Pioneer TS-WX140DA is only 70mm high.
    • People like Johnny Dose Bro might be laughing at my post because I accidentally added 100mm to my numbers. 350-355 is indeed the lower limit. 450 is off-road Skyline spec.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
