Calder has the slipperiest start. You'll get buckets of wheelspin no matter what you. For me buckets of wheelspin goes with buckets of torque steer so watch out if you're in the lane next to me :)
  • Replies 98
Posted Images
Typical of Calder Park.
You guys should organise Heathcote instead.
too far for me, was hoping to run this weekend and then the next one in a month after i had put in the pfc, z32, injectors and fuel pump and had it tuned and compare times, i guess i will just have the "after" times now.
Edited by W0rp3D
Yeah very typical of Calder...
The always f**k people around...Trackdays, 2litre SS days and practice, now drags, who knows what else...they should really just give up and so should we...
Anyone got 400m of land so we can build a dedicated SAU strip? :wub:
id be willing to go to heathcote if its on this weekend. if anyone wants to organise a small meet we'll all drive up 2gether :)
mmm dunno if that would be a good idea this week its the ford nationals and they are going to heathcote. so will be alottttt of them there....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
