Yeh too many tight corners, not enough fast open ones. And having tight turns at the end of long straights is a QR National defect so why copy that?
Actually a bigger version of the Club circuit could be good but its hard to tell the scale so....
Dont tight corners give more opportunity for overtaking rather than faster corners? I watched the hungarian GP the other week, thats a fast flowing track and there were only two passes all race.
Something like Mangy Cours... Sharp first turn, leading into a varying radius, sweeping second turn, which leads to the back straight (pretty long too) which terminated at the tight Adelaide hairpin.. Or something like La Source hairpin, tundering through Eau Rouge, followed by the Radillion kink which is linked to a long back straight, which once again terminates at a very tight chicane (Les Combes?)..
Probably my two favourite parts on any circuits on the F1 calender...
yeah its a bit of a shame - when they announced this it sounded like a major extension - but looking at the track map it is 99% same as current with some extra linking tracks so they can hire them out seperately and make more money :)
instead for renting the track for 10 a day now they can charge 30k
awsome
ardc suck teh balls
I thought the same thing. It's hard enough (and expensive enough) getting on the track now for chumps like us. I can just see them jacking up the prices to cover the costs....
Looks great, shame i probably wont be able to afford to drive there.....
Interesting that the new circuit runs clockwise now. Should mean lower speeds on the main straight due to running uphill, but then again, the old 'turn 1' will bring you onto the straight with more speed to start with.
I think the investment by the NSW government is a promising one as it will be drawcard for other motorsport events to come down under. However is it just me or is Sydney really bad for spectator numbers of motorsport and even sport in general? Eastern Creek was designed for motorcycles and have a look how that went, the GP is held in freezing cold penguin friendly Phillip Island. Being so close to Sydney I would have thought the numbers would have been quite large but you just have to look at recent V8 Supercar races to see numbers are well done, even when compared to those of Victorian rural races like Winton. I would hope that with the track investment they incorporate off street racing at a reasonable price to encourage young people to do it in a controlled environment and even offer subsidised driver programs for people under 25.
EC is a rubbish place to spectate, hence the reason the numbers are so low. Awkward positioning of stands and spectating areas is to blame for this. i don't see how this new layout will solve that problem.
i watched the super taxis there a while back. we could see them into turn one, down into the hair-pin, up over the top and disapear around the mountain, then back into view again. how much do you want to see? this was sitting on the hill. there is no seating position at any track where you can see the whole track. i payed $600 for my ticket at Melbourne, we saw them come down the straight through turns one and two and that was it. and i loved it because i was there. the atmosphere of being at the track is awesome, and nothing stops you from walking around to get different vantage points. sydney are just poor supporters of anything, whether it be sport or motorsport. i dont think the track has anything to do with it.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
