yes, another thread about poor results. i think it is the tuner? but ill see what you guys think
the mods are:
HKS GT-RS turbo
Power Fc
ACVR ebc
fmic
apexi pod
3.5inch cat back
3inch dump/front
xforce hiflow cat...also have bashed out stock cat, cant really feel a difference between the 2
BOSCH 040 fuel pump
Z32 AFM
Nismo 740cc injectors
with these mods i was expecting bout 350hp. but no
lol some of the stuff below may be a lil irrelevant, but i thought you guys might want to know the full story.
so i got my car tuned a few weeks back. got crap results at 300rwhp @ 1bar,
so the tuner reckons whenever put sets the car more than 1 bar the car starts knocking.
there is the ocasional misfiring too, but nothing major. so i thought it's ok for now
but the knock readings show on the pfc were hell high on normal driving, barely boosting and it reads 50+, and engine light comes on sometimes too,
so i took it back and he reckons he just needs to change the timing abit. and he does that.
all this time my boost gauge shows it's hitting 1.1-1.3bar, but i think it's because it's cold and has nothing to do with the ebc
ok so the car is still knocking. and fuel economy is shithouse. 260k's out of the first tank...my rear bumper is all black lol
so retune is done free of charge.
but the car still knocks and this time it's only making 290hp? @1bar again.
now fuel economy is now better but still not good. i got 320km's out of a tank..still a bit rich as i still get a black rear bumper after 2 days lol
and my boost gauge and ebc still reads the car is hitting 1.2bar, but again it may just be becasue of the cold weather
the knocking is still there, but only when the car is cold and for the first 5mins of driving, sometimes so high the engine light flashes. and im not boosting either
but when the car is warm and i give it shit it doesnt knock at all lol, stays under 30
tuner doesnt know what is causing the knocking. comp and leak down test has been done and it's fine.
What do you guys think it is?
im thinking of bashing out the xforce cat and put that in as it's 3inch and getting split dump and front....if thats gonna make a difference
and also splitfires for the misfiring problem
should i go back to the same tuner ? been there 3 times and he still cant find the problem..he says it's the car...but i think it may be him lol
here's the dyno sheet for the first tune. i dont think it has changed much.
do u guys reckon it's the tune? or do i need to change some part?
oh and my bov is very quiet for some reason, might quieter running at 1.2bar than at 0.8bar lol
also boost doesnt come on that early as some say about the gtrs, does that have anything to do with the tune?
cheers
Edited by ztuned
At 1bar peak boost pressure that seems about right for 300hp as thats around 230ish kw. However on 1.3-1.4bar you should be seeing around 330-360hp. Now wether its breaking down in spark at higher boost levels and not making more power could be the reason.
Does it missfire up high when it hits over 1 bar driving at night on full load?
i've only had it missfire on my twice...and it goes away once i lift the throttle up. and both times were at full throttle around 5000rpm
i think the missfiring issues should be alright after new splitfires, spark plugs have been changed too.
im more concerned bout why it knocks atm
and sorry this is the only dyno graph i have, dont know what that bottom curve is lol
Edited by ztuned
First and foremost...i have been in the exact same situation...my rb20 with hks2535 started off making [email protected] was piss weak...everything seemed fine with the engine at that point...compression was good and everything else was healthy...
Turns out my Xforce cat was a restrictive POS and was the biggest restriction in the whole system...i bit the bullet and shelled out $300+ for a MetalCat and went in for a retune...instantly we were able to dial in more timing and ended up with 215rwkw@16psi...
I went a step further and installed a catch can...which might have helped to catch some oil vapour which can lead to detonation...and i also invested in a set of new coils...another tuning session later and power went up to [email protected] wanted to dial in 22psi but was told not to push my luck...lolz...
Now take what you will from this...i know alot of skeptics who said that a catch can and coils wouldn't give a gain...but its all in the tune...allowing more ignition timing to be dialled in will in turn make more power...
I will however guarantee that the xforce cat is playing a part in your dismal results...i was using an xforce cat too...bin that POS and see if you can address other restrictions in your system...good luck...
1. AFR graph, if you dont have it... makes everything impossible to tell
2. Not a disappointing result at all for 1bar, sounds about right. I think you've got higher hopes than you should have as that result for that boost is pretty much on the money
3. Before you bash the cat, just drop the exhaust from before the cat. Simple and easy to answer that
4. I think you might need to see someone else
Just drop the exhaust off before the cat and do a run, then fit the cat do another run and compare the two result with this one.
Also sounds like your coils are breaking down, so make sure you get the Splitfires ASAP, and gap the plugs to 0.8mm
Here is my graph to compare to: The graph shows exactly what a shit cat can do to the overall power. Red line was using the original "hi flowing cat", blue line showing what happened with the "better" flowing cat ;)
18psi
Tomei Poncams
Head porting
Std bottom end
3" turbo-back exhaust
icic, knew the cat was shit, didnt know it could make that much difference like shown on Al's graph.
will invest in a new cat, is it worth it getting a 3.5inch split dump/front ?
new coils are definitely on the list, but is the catch can really necessary?
ne1 more ideas on the knocking? just a shit tune lol?
cheers
Edited by ztuned
change the coils and the cat then take it back for another tune, i think you will find the knocking will drop. with out the AFR's it is hard to tell, the other thing to change is your fuel filter is this hasn't been changed it a while it could be blocked
More boost! people run 14psi through they're standard turbo's. And given that you got restrictive standard manifolds that increase boost pressure but drop airflow you could run 20psi+ without worrying anything
Your bad fuel economy is due to your injectors, they're stupidly big for that amount of power. Its not going to change unless you change your injectors, 480cc s15 injectors would be much better for the application.
High knock levels at 1 bar is a bit weird, you haven't got an exhaust restriction to cause back pressure so it would have to be ignition timing. maybe your tuner needs to advance the ignition timing to safely increase boost levels.
I disagree with almost everything you just posted.
You started out ok with your third point, but then went off track again.
Bigger injectors don't always equate to using more fuel. They allow more head room. I'd suggest another tuner after all you've been through, if he keeps sending you away with your car knocking like that i'd be hitting him up for 7k for a rebuild pretty soon.
My fuel economy is fine with 800cc injectors provided I don't constantly lean too hard on the throttle. Mr33 is 100% correct in saying bigger injectors just allow for more headroom.
ztuned the power at 14psi seems pretty spot on, basically exactly what i made with it. with regard to the knocking get the mechanic to check your Crank Angle Sensor. inside it you should have these teeth which bight on with your cam. if these teeth are worn out you can expect to see your timing go all over the place. I had this problem and tuned it 2 times before one guy figured it out and all was good from then.
Mine on 14psi is 233rwkw
When I even got my hi-flow turbo on ages ago, the cat was the most restrictive thing I had...simple fix and a couple hundred later all good.
And now with the gtrs its still good!
Id also suggest seeing another tuner/shop.
Well worth getting another tuner to give it a quick run and check the tune out before changing anything major. If its running rich and knocking then the tune sounds pretty poor I just had mine looked at since I had similar issues and they got another 20kw out of it with a better A/F ratio and no knocking.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
