Um, I've got an R32 GTR with lots of mods running about 300 RWKW and I'm running the std airbox. I heard that pods give a much more audiable induction noise, but that they must be boxed so as not to be sucking in the hot air from the engine bay.
If so how is this best executed? Are there any other implications of doing this? I guess I'd like a few more exciting noises as right now I've really only got injectors and exhaust. Be nice to hear the induction and the turbos.
Thoughts?
https://www.sau.com.au/forums/topic/232339-pod-air-filters/
So you get your pods and then strap this over them. Where does the air get into the box? also ,what will this set up do for me? More induction nosie and will I hear the turbos? Cheers.
https://www.sau.com.au/forums/topic/232339-pod-air-filters/#findComment-4078053
In all honesty your better off keeping the stock airbox.
There are a number of cars making BIG numbers off the R32 airbox...
Pods only decrease performance of a streeter, in/out of traffic etc. All it does it suck up hot air.
Gotta ask yourself what you want.
Noise or perfomance?
https://www.sau.com.au/forums/topic/232339-pod-air-filters/#findComment-4078289
thanks Nismoid. Performance isn't the issue as there is plenty of that. Just looking for a bit of added wank factor. If that's going to cost me performance, then I'll pass on it. I notice too there is some possibility of this mod being illegal unless engineering which sounds like a pain to me.
https://www.sau.com.au/forums/topic/232339-pod-air-filters/#findComment-4079148
Legally you'll be ok if they are not oiled pods.
EPA ruling states you are allowed one intake modification.
So if you have the stock cooler, pods are OK.
No Engineering required in that department.
BTW - (bit of shameless plugging here) You should join the SAU-Vic club :)
www.sauvic.com.au
https://www.sau.com.au/forums/topic/232339-pod-air-filters/#findComment-4079294
BTW - (bit of shameless plugging here) You should join the SAU-Vic club :thumbsup:
www.sauvic.com.au
Wow, Victoria is lenient. No way you can do this in NSW. Pods equals defect, simple as that.
https://www.sau.com.au/forums/topic/232339-pod-air-filters/#findComment-4079742
I thought in nsw pods were legal as long as they are secured and enclosed?
Vic is not so free on a gtst, as nismoid said only one intake mod so its either a fmic or pod filter, although a lot of people take the chance and run both with an atmo bov and then come on here complaining how all cops are arse holes because they got defected for mods that are pure wank factor and they know are illegal.
https://www.sau.com.au/forums/topic/232339-pod-air-filters/#findComment-4079759
Yeah, sorry I should have clarified. Pods inside a air box are OK I think. Pods on their own, no way.
https://www.sau.com.au/forums/topic/232339-pod-air-filters/#findComment-4079766
BTW - (bit of shameless plugging here) You should join the SAU-Vic club :D
www.sauvic.com.au
Yes I should :thumbsup:
https://www.sau.com.au/forums/topic/232339-pod-air-filters/#findComment-4079802
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
