  • Replies 373
Posted Images
http://ripsltd.com/products.html
that basicaly goes through everything. if you are only looking for 300-350kw range the stock internal bottom end is fine (good for 600hp and 7200rpm) remember that all pricing on their site is in NZD not AUD.
Anyone know where is good to order online that is pretty quick?? I am after parts first week of November. Got a few places but not sure if they have all that I need so would be good to shop around.
Cheers :banana:
Send it up Kat...our head work is top shelf PM Jz R33 as we just did an engine for him that he picked up on Saturday.
Our engines have a proven track record taking out several Autosalon power championships and powering our R32 drag car to win the Australian title in 2004-2005. We have just built our current engine in our race car to push over the 1000hp mark and into the 8 sec bracket.
Im doing a couple of engines for ACT customers actually...you may know some of them.
Kat, make sure you consider this post!
LOL I'm happy to have 4wd and the more power she gets the happier I am! Haha rather have traction than fishtail down Gungahlin drive like what was happening when I had no front wheels engaging! :)
Do you know what yours dynos at the rear??
no idea at the moment...only got a 3 inch zorst and pod so i cant imagine more than 140ish 150ish at the wheels...plus i took the boost controller off so its running stock boost at the moment :) still enough compared to the old pulsar but.
it's booked in to autotech next tuesday, they are going to check air / fuel, try and diagnose that sensor problem thats making the car feel crap. hopefully give me a power figure then. when i spoke to the guy today he said it might jsut be easier to get a power fc so i can tune it n stuff...we'll see.
i bet the fishtail was fun hey? i had my first powerslide incident coming out of a round about the other day when it was raining...not as bad as what i expected it to be but...
Power FC FTW!!! Best thing I ever bought for it.... So far :)
Compared to the Pulsar must feel like a rocket!! I remember getting in the GTR for the first time after driving around a non turbo for 4 or 5 years... Haha OMG!!! :)
Well I've always had good results from those guys so they should be able to sort it out for you. I wasn't sure how stock yours was. At least it's nice and tidy, I like stock so then you can do whatever you want to it. Modding = expensive but awesomes!!!
LOL was a bit embarrassing cause was unplanned!
yeah my awesome powerslide was pretty much me jsut out of a roundabout...was going straight and put my foot down...hit boost was fine...hit 4K = loss of traction pluss bit of a kick
was kinda cool hehe.
where di u source your FC from kat??? can autotech get them or do i have to go through an online shop?? ive never shopped online before lol :) somewhere local supply them??
guess ill wait for them to tell me what the problem is first.
Sinista v1.0 (Black GTST) ran 178rwkw. Pod, Zorst, T-peice boost controller and 2530 turb.
Sudden stop at metal bus stop by next owner ~ 0rwkws :)
Wit you Jayce 3 local votes
Edited by Sinista32
Guys that have done this all before me, can you please let me know wht brands you have used for....
Cams
Pistons
Conrods
Injectors
Oil Pump
I have some ideas now and wanna hear what everyone else is using :banana:
Cheers.
Just been through it all, engine is at the builders now!
Cams: Tomei, Hks or other (not sure were already in engine)
Pistons: i went with Mahle pistons (Probably one of the best pistons you can buy) were around $900
Conrods: i went with Pauter. (also one of the best money could buy at the time) also were around $800
Injectors: i bought some 800cc injectors (i think they are denso) from slide on this forum (in the for sale trader section)
Oil Pump: Using N1 pump still. (with a well balanced bottom end, and staying away from rev limit launches etc they will be fine) will be looking at dry sump later on
Best thing to get is the nismo full engine gasket kit too @ around 4-500 bucks its very good value :P and you wont have problems with leaky aftermarket gaskets and seals..
I bought most of my engine parts in the Usa, while the dollar was at around .95, therefor i spend a bit more money and got myself Very good parts.
also got a n1 water pump for around 200 bucks from the usa..
As for other bits and pieces (jap branded stuff) got most of them from www.greenline.jp
I'm close to the 10k mark already tho i did buy a complete n1 motor as that was ment to go straight in........ haha
Edited by Angus Smart
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
