is anyone else having the same prob im having with very sluggish load times for the boards? doesnt matter where im logged in, whether it be school or home, or what browser...its as slow as a wet weak...
im guessing it has something to do with the new host, just thought i should check if its happening to anyone else.
and no, my net is fast and not capped :(
https://www.sau.com.au/forums/topic/232620-slow-load-times/
According to another thread, Prankeh currently has the new server up and running alongside the old one, with both pointing to the new database. I'd hazard a guess and say that if you're experiencing speed issues, you're connecting via the old web server.
If you're on Windows, try this command at a DOS prompt: ipconfig /flushdns. If that doesn't solve it (or if you're running an OS that doesn't cache DNS, like Linux) you'll just have to wait until your ISP's name servers are updated.
https://www.sau.com.au/forums/topic/232620-slow-load-times/#findComment-4082767
today if the first day in days ive (and a few mates) actually be able to get to the site at all!!!! kept going 404
thank god somethings changed because now i have sau again
still seems horribly slow at this end - like i am on dial up but im on 1500
but hey all good things take time :blink:
good to be back again
Edited by WHITE R32
https://www.sau.com.au/forums/topic/232620-slow-load-times/#findComment-4085846
Hey, has anyone else noticed that the sau site is really really slow. It took about 10 minutes to load on my computer, and sometimes it doesnt connect at all. Are there still technical problems with the new server, or is my computer fcuked?
https://www.sau.com.au/forums/topic/232620-slow-load-times/#findComment-4088436
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
