is anyone else having the same prob im having with very sluggish load times for the boards? doesnt matter where im logged in, whether it be school or home, or what browser...its as slow as a wet weak...
im guessing it has something to do with the new host, just thought i should check if its happening to anyone else.
and no, my net is fast and not capped :(
https://www.sau.com.au/forums/topic/232620-slow-load-times/
According to another thread, Prankeh currently has the new server up and running alongside the old one, with both pointing to the new database. I'd hazard a guess and say that if you're experiencing speed issues, you're connecting via the old web server.
If you're on Windows, try this command at a DOS prompt: ipconfig /flushdns. If that doesn't solve it (or if you're running an OS that doesn't cache DNS, like Linux) you'll just have to wait until your ISP's name servers are updated.
https://www.sau.com.au/forums/topic/232620-slow-load-times/#findComment-4082767
today if the first day in days ive (and a few mates) actually be able to get to the site at all!!!! kept going 404
thank god somethings changed because now i have sau again
still seems horribly slow at this end - like i am on dial up but im on 1500
but hey all good things take time :blink:
good to be back again
Edited by WHITE R32
https://www.sau.com.au/forums/topic/232620-slow-load-times/#findComment-4085846
Hey, has anyone else noticed that the sau site is really really slow. It took about 10 minutes to load on my computer, and sometimes it doesnt connect at all. Are there still technical problems with the new server, or is my computer fcuked?
https://www.sau.com.au/forums/topic/232620-slow-load-times/#findComment-4088436
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
