Item: r33 gtst series 1 1993 model Black
Condition:
hail damaged body
everything else in good contirion
Price: various just pm about the part you want
Contact: PM
Comments:
no motor no box
everything else there
most panels hail damaged
https://www.sau.com.au/forums/topic/232857-wrecking-r33/
hey mate
any interior pics?
stock steering wheel? condition?
just put up...you just chasing wheel?
Whats the damage for the rear calipers ?
Cheers A .
not sure please make offer through pm...what they worth?
what type of rear coilovers and how much mate ?
no rear coilovers?
Hey mate,
Any chance that the boot and drivers door aren't damaged at all?
Also, would you be interested in selling the boot lock?
Thanks,
Ben
boot is very damaged (apple sized hail)...drivers door suprisingly is that bad as you can see in pic...
https://www.sau.com.au/forums/topic/232857-wrecking-r33/#findComment-4085523
What sort of front bar does it have, is it the same as the one in my sig, if so im after that, the grill (especially if its black) the bar reo and the rear wing, give me a price with postage to vic 3200 and some pics of everything mentioned.
Thanks.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/232857-wrecking-r33/#findComment-4087997
i wouldnt mind the passange tail light assy how far up the coast are you
near lismore ballina
Is the rear wing in the picture still alive? Or did the hail get that too? How much if its still breathing? Send me a PM please.
rear wing is cracked from hail but easily repairable
https://www.sau.com.au/forums/topic/232857-wrecking-r33/#findComment-4109748
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
