this morning i happened to sleep in and was late to school so i was in a bit of a rush considering it was 10:15am..was gong through lights turning a corner and spun out as it was pissing down raining and was pretty slippery. Ended up going sideways around the corner unintentially as it was pissing down raining and spun out in middle of the road. Next thing i know while i continue to go is a undercover in a black unmarked VE pulls me up. checks the car does what a cop does and tells me "we'll be sending you a summons in the mail for reckless driving.
Just wanted to know what happens ect..fine, demerit points, license or anything..
i know i should have be driving more carefully specially as it was wet but i just had woken up and was in a rush. So i know i should have taken my time a bit. But yeah.
https://www.sau.com.au/forums/topic/232859-just-a-question/
i know if i wasnt ina rush i wouldnt have spun out and like i said it wasnt intentional to go sideways around a corner in the wet. im not saying i dont deserve whatever i get but i want to know what happens when i get a summons or whatever
https://www.sau.com.au/forums/topic/232859-just-a-question/#findComment-4083863
lol at the guys posting that he was driving recklessly blah blah blah its all ur fault now take it up the ass. he did own up to it and just wanted to know what would come of it.
but any way yeh tough break man...pretty harsh to give u a summons...but u'll just have to cop it and not be so fast next time.
good luck :P
https://www.sau.com.au/forums/topic/232859-just-a-question/#findComment-4084358
Both Reckless and Careless are summons offences for court. There is now a penalty notice for careless driving but I believe only can be issued to offending driver in circumstances of minor accident with no injuries.
I personally would think it's a bit harsh to get done for Reckless in those circumstances more likely Careless and fail to have full control of vehicle would be more appropriate.
I would say that if charged with Reckless you would be lucky not to get a suspension but if careless is the charge and you don't have many traffic priors then fine and points most likely outcome.
https://www.sau.com.au/forums/topic/232859-just-a-question/#findComment-4084673
yeah see i thought id be done for careless driving as what i did wasnt intentionally..i havent had any prior offences at all. i thought perhaps a warning or a on spot fine would have been sufficient as its not as if i did it purposely or do it for the sake of doing it.
and thanks everyone for the advice and info keep it coming if theres anythign else to say
Edited by blk_sz
https://www.sau.com.au/forums/topic/232859-just-a-question/#findComment-4084832
seek legal aid.....
I agree, I've done the same for careless driving in court. Vic Legal Aid is free anyway, so it doesn't hurt.
Just tell them you had no intention of doing what you did and you shat yourself and it was scary and you've learned your lesson, and they will probably go easy on you. I got 3 points and 150 fine, after doing something pretty stupid.
https://www.sau.com.au/forums/topic/232859-just-a-question/#findComment-4084840
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
