  • Replies 1.1k
The RST Gila will kill anyone using it for dirt jump. RST forks are dangerous. I had an RST fork once, 32mm stanchions and all 130mm of travel, the fork locked up for no reason, i crashed. Scary.
The only cable discs that are actually reliable are those from avid, bb5 and bb7.
The cranks are okay, isis stuff are okay, until the splines get worn.
I reckon for 300 its okay, i don't know much about the Australia bike stuff prices but if it was in Singapore, $300 is okay.
Edited by xALmoN
rst forks aren't that bad. they are just as good/bad as any other low end fork of the same price. the whole bike is only about $800 new. that is about half the price of a high end set of forks, LOL, so you can't expect the same performance. if you are regularly jumping the bike i would suggest getting a better bike than this one..... like a bmx, LOL
well isis spline cranks are about 1000 times better than square taper cranks (which i have seen stuffed after 1 day of riding). it's the same basic design as shimano use on their high end XTR gear, and there are a lot of high end bikes using isis drive. and similar systems are used on most bmx bikes with 3 piece cranks (although the high end stuff uses different splines).
as for cable discs, i don't really like any. sure some will work ok, but not as good as hydraulic.
just to be picky, the deity cranks aren't actually bmx cranks. they are a bmx style mtb crank, LOL.
but they are just a copy of other cranks on the market (as a lot of them are).
no matter what cranks you run though you still end up with the same problem, and that is that the bottom bracket is still a euro bb which has the weakest bearings of all of the bottom bracket sizes due to having to run cups and tiny bearings.
and then still being a mtb you will buckle wheels easier than a bmx due to the extra leverage, have weaker frames and forks and bars
i just know the brakes on this particular model are Chang Star mechanical brakes
but i got a pair of Tektro I0's on my bike now that im gunna swap over
cuz the chang stars suck ass.
Tektro I0's are really good mechanical disc brakes, they pull my 100kilo frame up pretty well
i do endos and everything no problem. skidss easily too.
Chang Stars sound china made and i don't think they're any good. I agree, chuck them.
Oh well, the deitys are pretty tested and proven so i'm partial to them, but i still use real mtb parts, cranks and all.
And Kyle, why don't you consider a hydraulic system? Something like a shimano deore, great brakes, and they're cheap. I'm from a humid country so i don't really recommend dot4 systems because they absorb moisture and expand too quickly. Like Hayes brakes.
Magura does good brakes too, like the Louise and Marta, but they're exhorbitant.
Cable systems require regular cable replacement, and hydro systems probably need a bleed every what, 1yr or so. And thats if you ride a lot.
tektro are made in asia as well. and the shimano's come out of malaysia, but shimano also has a few factories in china. a lot of the time the european or USA made stuff is only much more expensive because of the higher labour costs, not because it is any better. i used to sell a brand that came out of the same factory as another brand (even had the other brands name stamped into the back of the frame) and for an identical bike minus the name written on all the parts it was about 30% cheaper.
i really do get sick of people saying something is shit simply because it's made in china. it is only shit if the company who ordered it wanted it to be as cheap as possible and didn't care about quality. there are some rather respectable bike companies who do dodgy things when getting bikes made as far as saying where the bike was made. generally the high end asain made bikes we get here are from taiwan, and the cheaper stuff from china. however most of the factories in taiwan also own factories in china as well, so they will get things made in china, send them to taiwan and put the bike together with them but the bike gets classified as made in taiwan.
now the really cheap nasty stuff is starting to come out of india, vietnam and the philipenes
oh and cable discs don't require regular cable replacement unless there is an issue with the cable or the way it is mounted. they shouldn't require a cable to be replaced any more often than a regular brake system, and a good cable should last at least 5 years. i know people who ride everyday and haven't had to replace a cable in 10 years
Yes, i'm sorry. I was over-generalising.
Its about QC most of the time, not about the place where its made. I do use a lot of china branded bike stuff, like i used to ride an Echo Pure frame, with full echo parts. And taiwanese parts, such as Kenda Tires and Cheng Shin tubes.
I used to change cables a lot, derailluer cables were changed about once every 6 months and when i was using vees, i changed those every 6 months too. I use xt cables.
I'm told the cables would stretch actually, and when i was still using vees, i've had a brake cable snap on me on a wheelie, landed hard on my ass. I've been scared ever since. So i usually advise people to change their cables once 6 months or a year if one doesn't ride so often.
stretch it a hundred more and you can get an alias if you pay cash and shop around a bit. but truth be told it mainly comes down to what YOU WANT
most people these days automatically think "i want a mountain bike" - without thinking "how often do i actually go mountain biking???"... in the event that buying a mountain bike is not justifiable then consider a road bike! lot of people regard road bikes as being "sissy" or "gay" because of their riding position and skinny tyres. but the reality is - YOU'RE the one riding the bike, YOU'RE the one burning fat and calories and getting fit, and YOU'RE the one riding on the road when traffic is flowing then zooming past idiots in cars on the footpaths while they are stuck in traffic jams or stuck 500m back at a set of lights! so who cares what anybody says...
if you're looking at a mountain bike style riding position - put some skinnies on it and you have a bike that will cane *most* bike couriers thru urban riding
or if you want a dedicated road bike get a crx-2 - same price - similiar componentry only it's a road bike
the BEST option however - is go to a bike shop, mention your budget and take them for test rides to sort out what you like the most - that will make your mind up for you - not us!
well my other bike is a hardtail...haven't ridden it for a while but deff want somehting i can go trails with. ive got some neat ones jsut 5 up the road + i was something a bit more cruisey for the streets etc etc...
whats this alias you speak off...i havent really looked at bikes for quite a while.
umm why?
cables shouldn't stretch. they are prestretched in the factory. people who say they stretch (even people in bike shops) are idiots who don't know what they are on about. what actually happens is that the casing compresses, especially brake casing. gear casing is designed to be compressionless, but it does still compress a little bit.
as for brake cables snapping, the biggest cause if cables snapping is actually the casing and the cable adjuster. if there is a burr on the end of the casing it will wear through the cable. but if it is fine then as i said before, they should last years. my old road bike still has it's original cables on and the guy that owns it now does about 300km a week, probably more. last time it was in here for tyres the speedo read over 7000km and that was probably 6 months ago
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
