hmm, okay then i shall not ever get a fixie.
tsk, i need crank recommendations... my shitmano xt wouldn't stay on anymore. Or does anyone still have those old isis truvativ holzfeller cranks lying around in their garage willing to sell? I loved how those cranks were.
  • Replies 1.1k
i am assuming you have octalink cranks at the moment and not old XT that is square taper? also what gearing are you running? triple, double or single? also shimano octalink and isis drive spindles are different so you can't just swap the cranks over.
I know, i'm actually using the Hollowtech II cranks.
And i'm running on my granny ring.. 26t, and running a 13 or 15t cog a the back.. its currently now a 13t becaue i cbf adding a link back onto my chain.
so you are only running it as a sinlge speed? why not change to a set of bmx cranks? much stronger. i may be able to hook you up with a set of old cranks and a 25t sprocket. all you would need to do is buy a bearing set for about $50
ok, had a quick look at what i have in old stuff. got 1 set of bmx cranks but not really ideal as they have a 22mm spindle so since you are running it with a euro BB set it will destroy bearings pretty quick. the downside to running a bmx crank is that you can't keep the external bb shell which gives you better bearing life. but going to a bmx crank you are getting a much stronger crank and the weight difference isn't that much. if you are worried about it you could always put a titanium spindle in it. and bmx cranks are cheaper than mtb cranks. i looked up the price of a set of xt cranks before and the wholesale price on them is about the retail price on a good set of bmx cranks. and then once you take into account the cost of a sprocket and bb set the bmx cranks would still be cheaper and stronger.
i'm not a big fan of profile cranks. sure they are good, but there is other stuff just as good, if not better at the same price. i'd be going something like the colony colonial cranks.
as for fitting them. it's not harder than fitting shimano cranks really. you install one side of the bearings, slide the spindle through a bit, slide in the spacer then install the second bearing cup, then just plap around with the spacers until you get the right chainline and the right amount of spacers to have the second arm sit properly and have both arms clear the frame.
I've been racing Downhill for a fair while now.
Heres some of my current rides:
Banshee 2006 Chaparral - Custom race bike. Insured for $7k
Skate park/ Jump bike
2008 Eastern Thunderbird
Me in action:
State Champs Eagle On The Hill 2009
Nationals Eagle On The Hill 2008
Mt Torrens 2008
Mt Torrens 2008
Me in action:
Mt Torrens 2008
Mt Torrens 2008
Question, Have you ever landed a jump so hard that you've snapped your bike frame? or any other bike part for that matter?
I want a Cannondale Capo... $1750 one, the one with the Purple grips on the handle bars... MREPS put it up, where is santa when you most need him?
macdog - that bike is not worth $1750. if a shop is quoting $1750 for that bike you're describing they're having a lend of you.
it's worth $1,100 MAX.
it's a 2009 bike, it's clearance now.
anyway
results of my 53km bikerace. i am a retard.
the night before i decided to fully degrease and dry out my entire bike chain,. then re-lube it.
at the start line i noticed my back wheel wasn't sitting right - lube had got into the axle and slid one side of the wheel over. race started - by brakes were scrubbing the back wheel. had to pull over and re-adjust my brakes, this did nothing. so i hit the wheel back to somewhat straight.sliding the other side of the wheel over - causing chain sag..
chain sag and over lubed chain means chain comes off easilly.. so i lost about 5 mins pulled over with my brakes. chain came off 5 times... and i had to ride a bit slower so as not to hav the chain demount.. so in total i would've lost about 20 mins of my possible time - but - that's riding what can ya do
i finished in the 25th percentile of riders with an average speed of 28.9 km/h
very dissappointed witht he overall goings on ie - bike breaking down majorly.. but.. givent he circumstances.. to finish in the top quarter of riders i really can't complain..
EDIT - looks at BIT_SUSS's rides... my money's on NO. haha
Edited by Mr Eps
Are there any bikes with gears that would suite a 6 yr old ?
I road cycle and want my son to get into it, as he loves riding his little bmx.
But with no gears getting up hills is too hard for him.
you can get 20" mtb's that have 6 or 7 gears. whatever you do don't get a 20" with a triple chainring crankset. they don't have long enough chain stays to properly run a triple chainring set so you end up with plenty of chain issues.
you can also get 24" road bikes, but he wouldn't be big enough to ride one at 6. he would only just fit onto a 20" mtb at 6 unless he is very tall.
Then i'll kill my knees!
nah they are no worse than mtb's for knee injury. and gearing is moderate. not too easy but not too hard. i have crappy knees and i had no issues racing my 20". but you could always go a 24" if you are worried about it.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
