Bicycle Thread
By funkymonkey · Posted
Close. Not quite. You’re on the right track. It’s a super obscure car that not many people in Australia own or would’ve even heard of. A hint: it was developed to dominate a gaijin racing championship. -
By Watermouse · Posted
Sorry for the confusion, I meant would there be heat buildup internally in the S3 that would be detrimental to the ecu situated under the seat but covered over as suggested -
What heat build up are you asking about? Heat in the wiring providing the power to the Haltech, if remote mounted and power run via the fu(k-da-polees trick wire on the old ECU? Or heat from mounting an S3 inside an original case? I wouldn't run all the power for the Haltech through the trick wire. You just need the activation power. The main power would have to come from an appropriately fat feed. I wouldn't think you could fit the plastic body of a Haltech inside an original ECU case. They're pretty compact these days, but I don't think they're that compact.
