  • Replies 1.1k
  • 3 months later...
marc, do you have, uhh, spare cheap 26in rims that can take a beating and are pretty wide??? i dont mind 2nd hand stuff... because i'm building this...
I have a hadley front hub in black, i'm going for an a2z rear hub, or a pink king if i can find one.. shitmano deore hydro discs, and i'm running lx hollowtech cranks, Singlespeed for now..
Edited by xALmoN
rhynolites ding quite easily.. if only i could still source those tioga DH rims, could run really really low pressures and still be pinch flat proof!
and i'm thinking of building my own wheels, with a ghetto trueing stand made from a fork.. anything i need to take note of? or should i just send it to the shop.. but how much is labour here for buiilding wheels? dont need fancy ti spokes, standard steel ones will do. need a rough guide
mavic 521s were really good too...
Edited by xALmoN
I'm curious, what is the intended riding of the bike going to be? And I disagree on rhyno's dinging easily, I ride trials and have been witness to a lot of rim punishment and they stand up quite well to what gets dished at them.
trials/street/xc
gonna be running 26t in front and a 105 cog on the rear... everything bike, i want to be able to wheelie down the street, and then be able to pedal hop up the bench, then go ride in the trails.. i'm actually looking to get an older fox float rlc.. that rigid fork is only temporary, but its going to be a do everything bike..
well. i have an oval shaped rhynolite somewhere in my storeroom back in singapore.. too many stair gaps i reckon but those were the red ones.. with ground walls even! And you can't really run super low pressures on those... they go pssssst easily, But then do they still make those? I heard they've been out of production for awhile already.
My fav rims really are still the tioga dh.. there are new rims on the market, like the ztr flow, i've heard quite good things about those.. but really frankly speaking, i'm really still stuck in 2003... that frame was from that time.
To build a truing stand out of a set of forks won't work that well because rear hubs are much wider than fronts.
Can't really say what labour will be but i would say to expect around $100 for both wheels to be built
OT but:
Frame and stem combo might be a a little short for pedal hopping and bouncing around on the back wheel, But it does sound like fun, man I miss my STP Zero I used to have :ermm:
Back on topic, if you haven't built many wheels before you're better off getting some who knows what they're doing to lace them up for you. A good wheel builder will put together a lot stronger wheel with the same parts then you could expect to do on your first try....
Edited by JKR-32
if its about $100 for both wheels, then that's a pretty fair price, comparable to what i pay in singapore..
well, i used to ride a planet x jackflash.. and a echo pure.. they're long frames, but i had this stag as an xc bike for a bit. it works pretty well, with a short stem and rear wheel stuff, i'm not a big guy, so it probably won't matter that much. but then again, i've got a longer truvativ stem somewhere, but we'll see how this set up goes..
now i'll just have to source the rims and the rear hub..
  • 3 weeks later...
http://au.news.yahoo.com/thewest/a/-/offbeat/9046297/bicycle-made-with-computer-printer/
A bicycle made of nylon is said to be as strong as aluminium and steel - and yet it was made using a printer and computer.
The fully functioning cycle weighs 65 per cent less than a regular bike.
"Scientists in Bristol designed the bike on a computer and sent it to a printer, which placed layers of melted nylon powder on top of each other to build-up the machine," The Daily Mail has reported.
"Individual components such as gears, pedals and wheels are usually made in different factories and assembled into a finished bike but the Airbike is a single, complete part.
"The wheels, bearings and axle are incorporated into the 'growing' process, known as Additive Layer Manufacturing."
The Airbike - made by the European Aeronautic Defence and Space group - could be built to the rider's specifications and required no adjustment, conventional maintenance or assembly, The Mail said.
"The 3-D printing method allows products to be made from a fine powder of nylon, carbon-reinforced plastics or metals such as titanium, stainless steel or aluminium," The Mail said.
"They are drawn using computer-aided design and then sent to a printer, which is filled with the powdered material.
"A computer splits the 3-D design into many 2-D layers and a laser beam is used to melt the powder material into the first of the layers.
"This is then covered by a new layer of powder and the process is repeated with the next 'slice'."
The manufacturing process used about one-tenth of the material required in traditional methods, reducing waste.
"The technology is likely to be used in industrial applications such as aerospace, the motor industry and engineering," The Mail said.
Hey guys,
Well i need your advice on this one. After one of my staff bought a Giant Cross City 1 flat bar road bike to ride with me to work I can resist the urge to ditch the mountain bike for my work commute and buy one of these bad boys.
So i have been offered two pretty good deals one obviously better than the other
2011 Giant Cross City 1 - $1000 inc 1 free service
The other is 2010 GT shown here: http://www.bikepedia.com/quickbike/BikeSpecs.aspx?Year=2010&Brand=GT&Model=Tachyon+3.0&Type=bike
The beauty of the Tachyon is the very cheap price i am getting for, as its 2010 model I am getting it for $600 including 12 months free service so about 8 services in total. He was selling them for $900 6 months ago but now trying to get rid of em.
I have already bought a bike from the guy offering me the tachyon nice and cheap and the services always have been quality, his customer service aint the best but his prices are so cheap!
So what are your thoughts, cross city or tachyon 3? I like the fact that these are more path friendly than road bikes as a lot of my cycling is around a very large lake on the way to work so about 70 percent is path riding.
Also is there any upgrades you would propose? As I may be saving $400 i could be tempted to spend a couple of hundred just to give it an extra edge against the Giant Cross City 1
My staff member came to the shop with me today and had a ride on the Tachyon, he said he could not feel too much of a difference between his cross city 1 and the tachyon, but i am his boss so he could just be trying to be nice
Really would love to get your opinion on this....
Ok so i had a look at the specs. If the giant is in fact the cross city 1 and you can get it for $1000 (rrp of $1299) then do it. It's a much better bike than the gt. Even if it is the cross city 2 then i'd still go it (but change the stem to a fixed stem as the adjustable ones are shit).
Cheers for your help with this!!
You guys are going to think i am an idiot though as i couldnt resist. I bought it for $600 today. The Tachyon 3 by GT that is. I think the Giant is still a better bike, both the cross city 1 and the 2010 crx but the price of this was so cheap and the years free servicing i couldnt knock back as it has come in good value with my last bike especially in winter when the water would dry out all of the gears.
I think for $600 i could ride it for a year, sell it for $500 and in the mean time save up for a VERY nice bike indeed. I saw that Carbon flat bar road bikes are makin there way onto the scene so i recon i will end up with one of them in the future when funds allow.
For $600 i was really impressed with it and could only feel some minor differences between it and the Giant. The Giant had beautiful running gear (Shimano 105) and the gear changes felt amazing but for me being an amateur rider just commuting too and from work that was really all i could feel that was different. The Giant Cross City looks F*(kn hot though in white so that was the other factor. but for $400 difference i couldnt see that much of a difference.
So, NOW that i have this bike and have saved $400, what mods would you do? Remember i spent over 50k on my 33gtst so i cannot help to mod somehting on this bike.
Wheels?
Groupset?
anything else i could do to go quicker/better?
ahhaha!
I sell it to my wife that i save petrol money riding to and from work, what i dont tell her is that the amount of energy i am burning i need to maintain my size so i spend a lot of money at the cafe instead, so saving money from petrol for the car, but buying more food petrol for me :-)
Is it worth any sense putting a good set of wheels on it? if so any decent quality ones that would be an upgrade for me?
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
