I'm sure a lot of you have seen my car anyway... But here is some pics:
Can View more at http://www.sgv35.com
Beautiful car... maybe you should put your interest down here:
http://www.skylinesaustralia.com/forums/topic/393123-qld-photoshoot-by-tangcla/
I just picked this car up the other week, some of you may have seen it around Brisbane before with the previous owner. Most of the shots are from a Forge photoshoot before I got the car.
20" Forge wheels, Brembos, leather, bose stereo, coilovers, exhaust and a few other bits and pieces.
Overall really happy with the car. Just have to sort out some slight scrubbing problems on the front when hitting bumps and see if I can get the screen fixed. No picture showing up so I can't see what I'm doing...
Has anyone experienced any headlight problems with these lights? They don't seem all that bright on low beam?
Also I seem to be getting a "tick" noise when taking off and sometimes when changing gears. Sounds like it is coming from the rear brakes?
Hey Goodys, nice ride. Yeah ! Mine developed a ever so small "clicking" at around 60,000klms. Its so faint that even my mechanic cant work out where its from. I m pretty sure its a cv joint to the diff. I notice it when I first take off (sometimes 2nd gear), but definitely when you reverse then go forward.If it gets louder I will investigate further , but too minor to worry about now.
As for lights- the only issue with all skylines Ive had is the front passenger side parking buld. Usually just give it a bump & its good !
I just changed to LED'S as well as interior & wow thats good bang for the bucks!
Thanks for the info mate, I have a hoist handy so might have a look around and see if I can find anything near the CV's.
I just got home from a drive and decided to actually have a look at the lights while they were on and it seems I have 3 out of the 4 low beam lights out haha. I think this might be my problem. I will hopefully pull them out tomorrow and see if they are stuffed.
For anyone interested the wheels are 20x10 -0 with a 5mm spacer so effectively -5 front and 20x11.5 -0 rear. Not sure what the camber settings are or if there is much adjustment in them. Need to bring them in a little bit to avoid some scrubbing on bumps.
Also which interior bulbs/LED's did you replace? Any pics?
Yeh sounds like you have a short somewhere in the wiring. Replaced the Parking lights, Interior -headlining and door lights, boot and number plates also.
Just need to buy the clear indicator lense now. (had the car 4&1/2 years and just woke up to it now ! lol)
Anyone recommend somewhere in Sydney that sell them ??
I will post some pics when I do these.
Had a mess around today and it looks like it is just the RHS low beam bulb which has blown. It does not actually look blown but after connecting it to a battery I am still getting no light.
Will going to a "whiter" light give a bit better vision? How it is now I can't really see all that good on low beam..
Right now they are more blue than anything.
The lights are after market but not sure exactly what. Pic attached.
It's the rear axle bearing.. Very common problem with v35 Skylines.. It's nothing major.. Just an annoying sound
Edited by Megahowler
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
