Thought i'd also mention that the K2 Motor grille is basically a perfect fit, everything lined up no problem at all. Longest part of the swap was unscrewing those f*cking clips!
Ahhh should be good when you put the rims on, make sure you take pics and post it up when everything is done i gotta see this :D
Wow dude that's the next thing i was going to do is paint my original grill gloss black with a red Nissan badge, but damm that grill looks sweet as how much did u pick that up for?
Not to worry, i am a picture whore.. Every time something new happens i have the camera out straight away haha.. But i am really liking the camera in the iPhone 5 heaps good quality.
Here it is- http://www.ebay.com.au/itm/380474727964?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Pretty cheap, i'm happy with the look too. Only thing that is slightly annoying me is that the grille is really gloss black, shiny, in comparison to the mesh in the front bar it doesn't exactly match the darkness if you know what i mean. Tempted to paint the mesh in the bumper gloss black but it's too much f*cking around.
Here it is- http://www.ebay.com....984.m1439.l2649
Lol yeh i'm like that as well it's good taking a lot of photo's for the growing progress of how it ends up being at the end. Yeh the iphone does take good photo's man looks great.
Yeh i know what u mean by the difference between the grille and the mesh but you don't really notice it much unless your close up which is good.
Exactly right, i still have pics saved of when the previous owner sent some to me. Hasn't changed a great deal i have fixed up some things he had done and installed a few things but the next month - 2 months the car is going to look much different. Very keen!
Any plans for your own V Rob?
Yeh it's getting up there ay, taking time to build a car up is always more better at least you get to do some research of it and knowing what u want.
Yeh dude i'm looking at buying a high flow cat, Headers and a Motordyne plenum spacer next, I have just been doing some research on what sounds better and performance wise, Once i get all that put on i am going to do a mapless tune and dyno and see how much kw i get at the rear.
Sounds like you have it all sorted man, i personally am going to save the extra coin and go all out on MD tdx v2 + ART pipes.
In case you didn't know - as far as I am aware, properly fitting headers is an engine out exercise.
Yeh MD is the way to go, I have had a look on youtube with people that have the MD kit just sounds fantastic
Yup that's still stock suspension. I have plans to go low. Something OEM like 350Z or Nismo.
Thanks for the likes.
I've got Eibach pro kits waiting to go on 1.1'' drop all round which will be perfect for me as a daily drive. S-Techs i think go lower to a 1.5'' drop roughly same price. I am investing in coils soon though.
Yeah I don't want anything to low. A nice 1-2inch drop is just nice. How much are the Eibach or S-Techs priced at?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
