My v35 sedan. Just need to save my dollars and get an exhaust made up for it now. Full ikeya arms setup, need true rear coilovers but to run the rear toe arms. BC coils and 19x9+30 19x10+18 with 235/35/19 and 245/35/19.
oohh llaawwdd jezuz!! That is so simple and classy!! What would finish that off is a full WALD international kit of the V35. Well done sir, love it.
Amazing!
Edited by Howaitonaito
Here's my '05 V35 coupe. We had a photoshoot for my custom bike last year & so I thought I'd get some shots of the V while we were at it...!
I've had this one since it was imported in '08 & absolutely love it! I've kept it pretty stock-looking, as I reckon the V35's look really classy standard & have great smooth lines.
Externally its been lowered on Eibach springs, has 19" Koya RG-Teks all round, & I replaced the stock headlight units with LED DRLs from Spyder. I reckon that's about all it needs, I love the colour & the whole look of the thing.
Inside, I didn't want the 'premium' with the TV/Nav as I knew it would have the Jap symbols & be pretty useless. So I got Chris & Audio Express to fit a complete new double DIN dash panel with an aftermarket TV/Nav system & full OEM steering wheel controls. Now it's got full functionality & looks totally OEM!
nice one Bee! Just make sure you don't back into a human or else you will decapitate them :)
Cheers Jon, don't plan on killing anyone just yet lol
Why would anyone do that to their V
Because it's not your normal everyday V35 with a standard engine.you see most of the time.
Edited by 30Five
Hey Andrew,
Looking pretty nice.. Is that Stance SC-5ive wheels? What are the rim size, width and offsets for the wheels?
Raween
Hi Raween,
The wheels are ADV 5.1's in 20x11.0 +20, deep concave profile. I ran 20x10.0 +15 flat profile on the front for a while too.
Stance SC-5ive look pretty good, very similar to Vossen.
Cheers
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
