  • Replies 97
craz0
so now with the pfc in everything is fine and all u had to do was plug in with no extra wiring or mods to to the unit or wiring to make it work with the auto?
the only issue u have is the power light flashing?
steve-sst
how much is a wolf plugin worth for a r33 auto gts-t?
and who can tune it in sydney?
and as craz0 said when you installed the wolf into the auto r33 did u notice the power button flashing/going through the diagnostics?
Originally posted by walkoau
craz0
so now with the pfc in everything is fine and all u had to do was plug in with no extra wiring or mods to the unit or wiring to make it work with the auto?
The PFC worked and you can drive the Car, but the Auto speed button would flash 16 times (all fast) and when you run the Auto through diagnostic mode the third flash would be long (Throttle sensor shorted or disconnected) so the Auto needs the TPS signal to work properly, when I took it for a drive it would hold out through the gears (e.g. would change from first to second at about 3500rpm with your foot just on the accelerator where it would normally change under 2000rpm) after braking/cornering and then accelerating it seem to be in the right gear (like it wasn't fishing for a gear), It kicked back gears fine as well. When it did change from first to second it was harsh (like when you put your foot down from first to second and it gives you that kick but just not as fast and no wheel spin :P)
I can't seem to find a pin layout for the actual Auto ECU either.
Does anyone know what info Pins 5, 14 and 15 push from the main ECU? all three of these go straight to the Auto ECU.
I'm figuring they push the TPS and maybe Tacho signals so the Auto ECU can figure out when to change.
I've attached a pic of the three wires going into the Auto ECU.
Just seeing if anyone knows for sure.
  • 1 month later...
Ok i got the wolf plug-in and I pluged it in and the car didn't want to start and when it did it coughed and farted and blow dark black smoke and the lights on the ECU looked like Christmas lights going of,so I turned it of :confused: don't know what happened here.
The user manual I got with the ECU is for the normal Ver 4 but not the Plug-in version, I've contacted Wolf about this and I'm waiting on a reply.
Steve-SST do you know if there is different versions of the plug-ins at all? mine has (rev 5) on it, also the PC software I got for it is Ver 4.49 what version are you currently using?
So the MAP sensor has to be conected for it to work properly? so where is the best place to hook in the map sensor line? the fuel presure reg line?
Can you still leave the AFM hooked up or do you have to remove that as well?
My car is a 93 R33 RB25DET Auto everything is stock other then a Jamex filter in the original box and I run it on Optimax.
Steve Taylor sent me the first draft of the Installation Manual for the R32/R33 GTST Plug-In ECU, I haven't had the chance to read over it yet and the manual isn't quite finished.
Thanks heaps for your help.
My Email
Originally posted by GTS-t VSPEC
You can still leave the AFM in if you want, but just make sure in the software to choose MAP sensor. Try and get a clean plenum line if possible for the MAP.
What do you mean by "Try and get a clean plenum line if possible for the MAP"?
Where did you get your line plumed into?
Thanks GTS-t VSPEC
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
