Friday 26th September
Meet: Chatswood Chase Car Park, Enter off Victoria Ave
Time: 9:00pm, Leave by 9:30pm
Destination: Palm Beach via Newport for Pizza.
Bring: CB's, a full tank of fuel and a good attitude.
As always, don't do anything silly as we are on public roads.
YOU WILL BE REPORTED TO POLICE - this is NOT a joke
Pizza Place:
Lucky's Pep's Pizza Bar
Shp2/ 303 Barrenjoey Rd Newport 2106 (02) 9979 1756
Here's the list.. (no maybes here kthnx)
Marsss
Sl!m
DRD-00F
msnismo
Anna34
S13Deviat
D_I_F
Cassbo
SHANE666
PORTS
Goldzilla
Bakes
Xmetal
Kujotk
Blitz
Miss Turbo
FloydWestwood
GimpyDammit
LOOF
HOT_R33
Ari25t
v_s_p_e_c
Haysey
Primordial
https://www.sau.com.au/forums/topic/233356-who-wants-p-i-z-z-a/
  • Replies 115
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
