http://www.motorauthority.com/news/videos/...ailer-released/
Paul Walker and Vin Diesel return for the fourth instalment of the Fast & Furious series and once again play characters caught up in the seamy underworld of truck hijacking and stolen cars. The first official trailer for the upcoming movie has just been released, revealing that a number of other characters from the first movie also return. We also get a look at some of the new of the film, including a Subaru WRX STI, a Chevrolet Nova SS, a couple of Nissan Skylines and even a Buick Grand National. The movie is set to open next summer but in the meantime follow the jump to catch the new trailer.
nice, actually looks like it could be good! Dare I hope for a PROPER sequel to the first Fast and Furious?
Nice to see a couple of R34s in the mix too, I also managed to spot a Ford RS200! The Subie STi wasn't too over the top and that Buick GNX at the start is beautiful too. Is it possible that the car people on an FnF movie have discovered a modicum of taste?
Everyone slags off FnF films, but really, why do you watch them? To be entertained. If i watch a film, and walk away entertained then the movie's done its job. Some entertain with engaging storylines, others with cars explosions and tits. FnF falls in the latter category, but you still wind up being entertained.
FnF4 will be more of the same entertaining explosions and tits.
Well said. Now bring on the explosions! and tits!!! :D
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
