  • Replies 115
Who cares what it sounds like? :P
Quote from the ESP guys from the last ESP dyno day thread:
"Hope everyone had as good a day as us and we are looking forward to the next day. We have made some enquiries and got some sponsors for the next day as far as prizes go"
Prizes - Hope there's one for 'most power on stock airbox' :cool: De-fault! de-fault!
Me either, I won't win anything - just read it and thought I'd paste it here :cool:
edit: nm read earlier post. I'll be out there about midday or so.. hope I don't miss anything too interesting!!!
Edited by sl33py
Congrats to everyone's efforts today. Thumbs up to Chris for organising and ESP for running it. I think there were a few people that walked away with a lot more knowledge and some asking themselves (or their other half) how much money they can spend before the next day....
I was very impressed and pleased to know that ESP's dyno read 1kw more than Jake's Performance. Consistency was near spot on!
Thanks for taking us for a quick lap to Ben, opened my eyes/ears to what a 1.5 way is like.
No probs, thanks to ESP for running the day, and going that extra mile, really appreciate it, and for everyone that showed up. Was great to see the R35's there, stunning cars and certainly put out some nice power. Already am thinking about spending some more money on my car lol :)
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
