At the end of the day you should select a tuner who has greatest experience in the ECU you would like. Or, if you know someone that you want to tune your car, he will make a recommendation in what he feels he can tune correctly (if he is honest).
Whether is uses MAP sensors of AFMs is does not matter at all, if the tune is right there is no noticable difference when you are driving.
PFC is a great ECU especially for a street car does exactly what you need but personally there are other ECUs that can do things better. For example, I chose a Vipec V88 one of the reasons being it has knock control which I think is essential (my opinion).
Read every post but do not take any of it as gospel, people have opnions (sometimes very strong ones) and that over shadows a lot of truths and factual information. Do your research by talking to different tuners and make a decision based on what you want out of an aftermarket ECU and weighing up the pro's and con's of each.
Good luck,
Mike
3. Make sure that ECU at least is semi-common so if you have an issue later, you can switch tuner without much issue
Thats the main reason why ill be going power FC. I know if i hit a snag some1 will have had the same thing happen.
Edited by joeleo87
Nistune/remap same soft of thing. Extra $200 in getting nistune setup but its great had it in my 32 gtst and will be using it in my gtr
I tune for a living and am happy to do all 3, NISTUNE (3 or 4 week, but mostly s13), WOLF ( about 3-4 week) and POWERFC (about 6 -10 week) BUT for your application POWERFC for sure. It has the best aftermarket support ie can be tuned anywhere. The wolf V5 is not a bad piece of kit but after doing quite a few i think the extra cost is not worth it over a PFC.
PFC FTW
agreeing with Trent ^ Power FC is great for your application, i have run a power FC on a 300kw GTR with nismo AFM and was great, the only reason i went to autronic was cause of AFM's on a single set up, and cause at the time i couldnt find a d-jetro but would certainly look at one now and am actually considering going back to power fc just for the ease, and more than anything the handcontroller gibves you everything you need on a simple display.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
